NEWBIE FROM SOMERSET
  • #646201
    Dougie
      @dougie
      Hi everyone,
      I thought it was about time I registered and introduced myself after lurking on the outside for sometime.
      Recently retired after latterly working in the fabrication industry and prior to that servicing industrial pumping equipment for a number of years.
      In the garage I have an 80 year old Rivett lathe with a lot of other equipment built up over the years, and when it gets too cold out there I have a small room in the house with a Sherline lathe and mill set up beside a radiator…
      I have managed to acquire the casting and drawings for Les Chenery’s Gnome rotary so hoping to make a start on that shortly so expect some questions to be asked, it should keep me going for the next few years.
      Cheers
      Dougie
        @dougie
        #646245
        Thor 🇳🇴
          @thor
          Hi Dougie,
          Welcome to the forum and good luck with your Gnome.
          Thor
          #646259
          bernard towers
            @bernardtowers37738
            that's going to keep you busy but the end result will be something special. I am working on a 0.1 Ci single at the moment and the problem of limits and fits is stretching me I fear, best of luck and keep us updated
            #646266
            noel shelley
              @noelshelley55608
              Welcome Dougie, An interesting project, Until I foolishly lent it out I had the original workshop manual for the Monosoupape Gnome rotary. Ah well. Best wishes Noel.
              #646270
              Dougie
                @dougie
                Thanks Thor
                #646271
                Dougie
                  @dougie
                  Thanks bernard,
                  TBH having only just retired I hope it does keep me busy, need to keep those brain cells active !
                  #646273
                  Dougie
                    @dougie
                    Thanks noel,
                    I think I might have a copy of the manual buried somewhere on a book shelf, I seem to recall buying it from Camden Steam 20 years ago or so…will have to have a rummage, thanks for reminding me about this.
                    #646279
                    Howard Lewis
                      @howardlewis46836
                      Welcome!
                      A rotary is an interesting, and probably, testing project.
                      Well worth documentinmg as it prgofresses.
                      #646317
                      Dougie
                        @dougie
                        Thanks Howard,
                        Points noted.
                        #646332
                        Harry Wilkes
                          @harrywilkes58467
                          H
                          #646343
                          Dougie
                            @dougie
                            Thanks Harry
