NEWBE IN HAMPSHIRE
NEWBE IN HAMPSHIRE
  • #524224
    Glenn White
      @glennwhite74848
      HI have just got a Harrison VS330TR am going to be looking for lots of advice on what to do and how to do it, and where to get things from and what are the right things to get
      Glenn White
        @glennwhite74848
        #524260
        David George 1
          @davidgeorge1
          Hi Glenn welcome to the forum. That is a nice lathe as long as it has been reasonably looked after. What do you want to make as that you can make a few tools as projects to get to know your lathe. A tailstock die holder is a useful piece that can be made easily or other things that you will find useful.
          David
          #524261
          Brian H
            @brianh50089
            Hello Glenn and welcome.
            You've certainly come to the right place for help and advice, ask away.
            #524270
            Clay Jones
              @clayjones22389
              Hi Glen
              Newbe myself from Hampshire. Certainly seems a good bunch on here and certainly knowledgable. Where in Hampshire are you?
              All the best
              Clay
              #524288
              Howard Lewis
                @howardlewis46836
                Welcome
                Seek and ye shall find.
                Folk on here have LOTS of experience in all sorts of fields, so ask away.
                +1 for getting used to the lathe by making things.
                Centre Height Gauge.
                Tailstock sliding Die Holder.
                Tailstock sliding Tap holder
                If it can be fitted, a Rear Toolpost will be invaluable for parting off.. (I made a four way one, looking like the front one, for my lathe, so that it can be used for front chamfering, back chamfering and parting off .
                A lot of us are enthusiasts for a Tangential Turning Tool. You can either make, by scaling up one of the designs published in MEW, or you can buy. The HSS toolbit is easy to sharpen, using a simple jig.
                A Centre Height Gauge is necessary for this.
                Having said that, it will pay to learn how to grind HSS tool. From time to time you will need a "special" that only you can make.
                These activities will bring you experience of using the machine, cutting speeds and feds, which one day you will extend into screw cutting. (Mostly, for threads smaller than 1/2" or 13 mm I use Taps and Dies, but you may need a "one off Special" one day.)
                In these activities you will learn about the different thread forms and pitches.
                You will find a set of Zeus charts invaluable. Still using mine, bought in 1958.
                If you want some reading to learn basic principles:
                L H Sparey "The Amateur's Lathe" Dated, but the basic principles remain the same.
                Ian Bradley "The Amateur's Workshop" Deals with fitting work, as well as good advice on setting up a Lathe.
                Harold Hall Has written a book on Lathework among other things (A former MEW Editor )
                Eventually, you will find books in the Workshop Practice Series useful. Buy them as the need arises.
                To spend even more of your money, in addition to a bench Grinder, you will soon need measuring equipment.
                A digital calliper will probably be the first, since it can be changed from Imperial, which I suspect your lathe will be, to metric if you choose to work in those unit. I still have the Rabone Chesterman vernier calliper that I bought as an apprentice. Good tools may be dearer, but they last longer!
                If yo start using a 4 jaw independent chuck, you will then need a magnetic base, and one or more DTis; ideally a plunger clock in thous, and a finger clock in half thous, to centre work in the chuck.
                HTH
                #524609
                Glenn White
                  @glennwhite74848
                  Thanks for the welcome . Funny thing is I don't have anything in particular i want to make just want to make something and see where it takes me , i do have some Vauxhall hb Viva's and fd Victors that I am restoring ,so may need to make something for them , but i have always been interested in lathes and mills .
                  And Clay i am near Romsey
                  #524626
                  Clay Jones
                    @clayjones22389
                    Man after my own heart Glenn, bought my mill and lathe originally for my Classic cars and spend a fair bit of time at Fishlake meadows in Romsey.
                    All the best
                    Clay
