Home › Forums › Model Engineer & Workshop › New technology in Model Engineers Workshop
Derek Brown’s Metric Conversion System works very and is quick to change. I have one on my Myford PCF Super 7 since it was first published in ME some years ago. Yes John S I also have other lathes including Harrison M300 so that does not make me solely pro Myford, in any case the flat bed plain bearings only really applies to the ML7.
Hi All
Maybe the easiest way to consider what changes are made using mineral casting is to try redesigning a known design.
The Warden design Grinder is a good starting point. A simple machine made from sheet metal.
In the drawings below the base, Motor support pillar and the sliding end plates have been redesigned to use Mineral castings.
The Base is a 50mm cast slab all mounting holes will be placed by casting in pre drilled and counterbored 50mm long sleeves of mild steel, the outer surface of the sleeve to be knurled or slightly ribbed in the lathe; this will remove any possibility of them being driven out. Light 8mm steel reinforcement will be placed around the periphery and in a 100mm grid pattern.
The motor pillar is a solid cast block that will be epoxy resin glued to the base. This will form an extremely solid mount for the motor. Epoxy Concrete has about 8 times the damping of cast iron and a great many times more than that compared to sheet metal. This should greatly reduce vibration and improve the surface finish obtainable. I chose to draw a .5hp frame size motor, although there is room for a larger rating if required. I provided for a taper lock removable wheel mount so that multiple wheels could be easily changed and remain centered.
While reviewing the sheet metal design I decided to make the table movable in both the x and y direction. In addition to the angle Z plane. Note the two knurled knobs for adjustment. These would turn simple feed screws loaded against a spring to remove any backlash.
Note the thickness of the end plates, provisionally 50mm, this allows 25mm holes to be cast in for the round shaft rails. I deliberately chose this size to get a large bearing area. As cast the clearance will be between .0001 and .0003. The gap being the release agent applied to the shaft to stop it sticking. This is where cold casting really excels. Alternatively precision bushes could be cast in or bush retainers if you want to take a belt and braces approach and have replaceable bushes.
The table is 12mm steel Supported on steel bearing blocks screwed to the underside transferring the table load to the 20mm steel shaft that runs between the end plates. The end plates again greatly improve damping (The table angle adjustment cams are not shown I want to review that design)
This is a concept design it is not finalized, however it would not take a lot of work to make it so, unless inspiration takes charge forcing a redesign.
The casting process is no different to working with cement. The aggregate mix of 5-8mm graded aggregate, ideally rounded pebbles and washed silica sand for the base and coarse washed silica sand only for the end plates is mixed with approximately 9 – 12 % Epoxy by weight. Ideally less is better. This week I take delivery of the epoxy I have chosen to test. I will report back my findings.
Cheers
Edited By John McNamara on 21/05/2011 18:22:16
Criticism
Carl Sagan said of Plato: “Science and mathematics were to be removed from the hands of the merchants and the artisans. This tendency found its most effective advocate in a follower of Pythagoras named Plato.” and: “He (Plato) believed that ideas were far more real than the natural world. He advised the astronomers not to waste their time observing the stars and planets. It was better, he believed, just to think about them. Plato expressed hostility to observation and experiment. He taught contempt for the real world and disdain for the practical application of scientific knowledge. Plato’s followers succeeded in extinguishing the light of science and experiment that had been kindled by Democritus and the other Ionians.”[
This IS a thread about new technology. We don’t just think about it we do it.
Thank You
John McNamara
Edited By John McNamara on 21/05/2011 18:52:57
That’s much more in the spirit of the discussion.
Hi All
I have been thinking about the moulding methods rather carefully. As the materials arrive this week and I will be starting to get my hands dirty. Something I like very much. It is great fun to get through the design stage, but the real fun is when the idea takes physical shape.
The method of casting depends on the accuracy required in the finished part. Unlike sand casting where a 5 to 10mm or more allowance for roughness that needs to be allowed for, and must be machined off later, we can get good accuracy straight from the mould.
If you have a surface plate pre waxed and additionally protected by a polyethylene sheet. We do not want to damage an expensive piece of kit like that. We should be able to get flatness better than .001inches provided the surface plate is true.
I also have a piece of kitchen bench top granite… A sink cut out; most kitchen companies have lots of them. They are surprisingly flat to better that .001. OK that is a generalization the one I found was flat to within .001 tested on the surface plate.
In the case of the Warden grinder in reality this kind of accuracy is not required for the base. Considering that the sheet metal version base is likely to have errors an order of magnitude greater in the .1 to .01 range… OK although certainly not optimal for the design. The sheet metal base does have two ribs however as an open shell it must flex under load.
My plan to make the form work for this project is to use Melamine coated MDF I have to hand for the base… I plan to make the base upside down so the top surface will lie against the bottom of the mould the 50mm strips forming the sides creating a tray to contain the mix will be screwed on to the base
The chamfers will be formed by pieces of timber or ideally plastic beading obtained from the local hardware and glued in position. I have no plans to reuse the mould so no draft to allow removal has been used. The mould will be destroyed upon removal. Commercial users of this process make multi segment metal moulds. There is nothing to stop us from doing the same if the need arises.
The Motor support column can be made in the same way, just a simple cube.
I have been warned by a friend in the Boat building industry of the pitfalls of using Silicone mould release if you plan to paint later. It is almost impossible to completely get the material off your casting and will seriously frustrate your paint finishing. The boat builders use Carnauba wax or commercially made silicone free products. Your resin supplier will have them.
All mounting points should be cast in position… Two methods come to mind for this, one to drill through holes in the mould and screw the inserts in position from the back this will keep them nicely planar to the surface of the finished product.
Alternatively if extreme accuracy is required solid metal inserts could be prepared and glued in position to the mould walls. They can be marked out, drilled and bored by conventional machining methods after the casting has cured. With a little planning the second option should not often be required.
This is what the micron level machine builders do. They also precision grind the mounting ways, including the cast in screw inserts.
A third alternative is to cast in, holes using say Styrofoam blocks; we want the holes to be rough inside preferably with a little undercut for a good key for the next operation; they can be picked out and washed away with solvent later… Then we can “cast in” this time using an epoxy grout, a precisely positioned mounting. The accuracy achieved will be directly proportional to our ability to pre position it.
Shrinkage: I have not mentioned shrinkage because all of the literature I have read over the last six months that I have been researching states it to be negligible. Even if so Gravity alone will obviously affect the finished casting, as will applied load forces, Temperature and many others.
It is important to mention here that Epoxy resin and Polyester resin systems are completely different. Epoxy resin has two parts and good quality epoxy does not have added solvents. Polyester resin systems as used in boats for instance in addition to the catalyst use solvents in the cure process. They shrink as the solvents evaporate and are totally unsuited to our need for precision machinery; as is conventional Portland cement even worse and the tensile strength can be regarded as negligible due to micro cracking.
The two end supports for the warden need a little more work in preparing the mould.
There are a number of through holes; the inserts for them need to be exact length 50mm in this case to match the 50mm width of the casting.
That leaves the 25mm nominal hole for the guide way shaft. I plan to increase this to 30mm. I will then position and cast in the round rail later using a bearing mix. Please see: “epoxy bearing material and method” posted on this site.
Alternatively others may prefer to cast in steel inserts and later fit bronze bearings. There will be no trouble holding it for machine the existing holes can be used to screw it to the setup you use to hold it.
Edited By John McNamara on 22/05/2011 09:25:19
To Paul Boscott
Thank you for your words of support. Yes 3D printing is coming of age particularly in prototyping. And as you no doubt know there is an active community of do it yourselfers engaged in research. I am waiting until they get past the glue stage and start using powder and laser fusion.
To Chris Trice
You are correct machining parts made from epoxy concrete should be kept to a minimum. A small tradesman’s angle grinder with a diamond wheel (now so cheap at a few dollars each) can be used to clean up the castings particularly the top face with its toweled finish and square corners. A masonry bit and hammer drill could be used for rough oversize holes, if our bio computer forgets to cast in a hole in the first place.
I do not plan to use the castings raw. Our great friend builders epoxy patch. “Builders bog” in Australia will be used to patch the inevitable defects then a good coat of etch primer and paint.
In Australia I will be using the “Megapoxy H” system. Depending on quantity about AUD 15 dollars a Litre that translates to about ten UK STG pounds a Litre. Add to that the cost of aggregate and sand.
The fancier garden supplies sell fancy washed and graded pebbles by the bag. The same applies for sand. The pebbles and sand must be completely dry before use. They can be laid out in trays in a dry place or the domestic oven used if allowed by SWMBO.
The Base of the protype design measures 500 x 350 x 50, that equals 8.7 litres I do not have the actual plans for the Wardon does anyone have the number of MEW when it was first posted? I suspect the actual warden may be smaller.
Given that the ratio of epoxy to aggregate is in round terms 10:1 by volume well less than a litre of epoxy will be needed for the base.
Bags of aggregate cost around on average 15 dollars in Australia If bought by the Cubic metre a fraction of that.
Getting started is always problematic for the first use of a new process. Maybe the first attempt will be less than satisfactory. So an allowance for experimentation has to be made. However we are not trail blazers here. This is known technology.
Vacuum degassing? Yes in a perfect world a good Idea however not essential any defect can be patched later. We are making one offs I am pretty sure the people in this room will take great care in laying down the mix. A means to vibrate the mix while being placed will be useful in larger mouldings.
Setting time is an issue it is temperature dependent, casting in very cold weather delays the setting time. At typical ambient 72 degrees F about 20 minutes for the Megapoxy H I intend to use. Different products have different setting times. Check your supplier.
For bigger castings I plan to make smaller batches and lay them down in layers of an inch or so.
Epoxy is exothermic that is it generates heat while curing. If you mix a batch and just let it sit in a bucket it will “Go off” very quickly. Again from my study of others work when added to the aggregate the heating is a lot slower as the aggregate absorbs the heat thus slowing the setting. Normal Portland cement based concrete is the same it also generates heat while curing
Provided the casting has cured at normal temperatures the formwork can be stripped in 24 hours. For freezing conditions artificial heat or extended curing times may be needed. You epoxy supplier will provide a chart of curing temperatures. Not a problem in Australia but needed in colder climates.
Artificial heat up to about 70 degrees C for Megapoxy will greatly reduce the curing time. I used an oven to heat the test pieces of the epoxy bearing material actually to 100 degrees C the curing time was about an hour. I am not going to do this with MDF formwork, but it is handy to know.
My final thought is about the aggregate mix.
This is going to differ depending on where you live and what is available.
Do a Google search of “Epoxy Concrete Aggregate Ratio Mixing Method” I am going to thoroughly test this method and will report my findings. There is a lot of variation within the community of what the mix should be. Commercial interest is also coming into play here, “Secret herbs and spices”! However a little basic research will come close to an Ideal mix.
There is also talk of nano particles, Carbon filaments and a host of high tech materials. A lot of it is hocus pocus… We are not designing for the space shuttle.
Epoxy concrete will never have the tensile properties of steel. Approximately one fourth that of steel, confirmed by numerous PHD level reports I have found on the net. It has properties roughly equivalent to Aluminium to counter that we use heavier sections. As is the norm particularly with support structures in machine design, it is deflection that is our enemy strength rarely is the issue, and heavier sections counter that. We also use extremely cheap steel reinforcement where needed. A six metre length of 8mm deformed bar, as used in construction, costs a few dollars in Australia, for smaller parts save those coat hangers. And keep an eye out for scraps at building sites.
Continued next post……..
To finally analyse cost particularly with regard to cast machine members there is a clear cost advantage to using composite materials. For the home based constructor this is a no brainer. It puts the means of production back in the hands of the constructor. It is not high tech, a flat surface to work off and woodworking tools to make the formwork, a small triangular trowel and rectangular trowel to finish off the top surface. A micro lathe to make the cast in mounting points and you are away.
It is important that homage is paid to and is due to the Warden design. The basic principle of operation has not been changed. By doing away entirely with the sheet metal frame components and changing the table top to 12.5mm steel instead of light plate new technology has created a much more substantial machine the will no doubt create a fine finish on the tools it produces at a lower cost of materials to build it than the original design.
Cheers
John McNamara
Edited By John McNamara on 22/05/2011 09:33:03
Hi All
Update on Worden…Epoxy concrete base poured
Formwork
As seen in the photos a sheet of Melamine MDF board was used as a base to build an enclosing framework 50mm high. A number of simple steel angles were used to join the framework to the base, and to hold the corners in place.
Note the quarter round plastic insert at the bottom of the mould. The drawings show this to be a 45 degree arris however a suitable moulding was not available. Therefore a substitute was made; 10mm tile bull nose strip, a length cost $6.00 in Australia. After mitering the corners on the drop saw, the long edge that normally goes under the tile was slipped under the edge of the framework to hold them in position.
The frame was built over a 1:1 drawing printed on an AO sheet of plain paper, placed on the base board. I have a plan plotter. The positions of the screwed inserts were punched through the plan to mark the backing board. This method is fine where the accuracy does not have to be better than about .25mm. Otherwise the holes could be marked out by hand.
The screw inserts are M8 left over from another job. They are actually threaded on the outside as well to be screwed into MDF cabinet maker’s suppliers have them. As they are a bit short I used two on each M8 bolt screwed in from the back of the board and tightened securely to be removed later. The ends of the inserts were sealed to stop the epoxy from seeping into the thread and locking it. If these inserts were not available I would have made them from mild steel rod. By drilling and tapping M8 and grooving the outside diameter to give a key for the epoxy.
12mm deformed concrete reinforcing bar was used for reinforcement I tied the bars to the inserts prior to pouring. A little overkill bit it was in stock. 8mm deformed bar would have been fine.
Once complete a “Gel coat” was brushed on to the base and the inside sides. This coat comprised “Megapoxy HICB” a product normally used in mining in rock crushers! It contains fine silica for added strength and is a bluish colour. To dye it grey I added 4 teaspoons of graphite powder this turned it a black grey colour about 300mls was used.
As I am experimenting with both HICB and plain epoxy I had it to hand, it would be just as good to use plain Megapoxy H.
7mm screened quartz river sand was used as the aggregate, visual inspection reveals it to be about 70% quartz to this I added 25% by volume fine washed sand. Both the sand and the aggregate was heated to 200 degrees Centigrade to dry it, A slow process you have to spread it out on trays about 3cm max thick. Otherwise the moisture just stays in the lower levels
Cont Next Post
Edited By John McNamara on 30/05/2011 17:33:15
The 25% ratio for the sand was calculated filling a 810 ml tin plated food can right to the top with aggregate (Which was then carefully weighed) placing a large gear over it and introducing sand into the hole in the gear while wrapping it all around the sides with a light metal bar, until the mix started coming up the hole, At which point the can was tipped into a bucket and stirred, The mix put back in the can and the process started over until I could get no more in. A process that took about an hour to complete but it only has to be done once (Unless you change one of the materials). The Idea is to fill all the voids between the aggregate with sand. The last step is to weigh the sand aggregate mix you just created subtract the weight of the aggregate which gives the weight of the sand needed. By carefully weighing out that quantity of sand and placing it in the same tin you can measure the height. In this test it was a quarter of the can. 25%.
I calculated the base 500x350x50 to have a volume of 8.75 Litres
Using the food can I mixed as follows
10 x 810ml cans of aggregate
2.5 x 801ml cans of sand
As per our findings above we have a volume of 10 x 810 cans = 8.10 litres of aggregate mix; the sand was absorbed.
For the aggregate mix Megapoxy H was used this is a clear liquid and the hardener is similar. (I believe it may be Available in the UK I found a site on the net)
810 ml of epoxy 270ml of hardener was used meaning that our base is about 13% by volume epoxy. Not bad for a first test. After the pour was finished visual inspection revealed it may be possible to increase the sand a little. I will also try a little less epoxy next time with an objective of sub 10% epoxy. Less epoxy should result in stiffer deflection properties. Yes it will also save a little expense but that is not the objective here.
The actual mixing was simple and quick. The epoxy and hardener first in a small container, they must be carefully measured and very well mixed.
For mixing the aggregate two 20 Litre pails were used.
The aggregate and sand was placed in the first pail then tipped into the second this process was repeated until the sand and aggregate was mixed, then the Epoxy mix was gradually added and the tipping form one bucket to the other was continued until a homogeneous mass was obtained; in about ten minutes we were ready to pour. When poured out the epoxy had evenly coated the aggregate and sand, it tipped out of the bucket quite cleanly leaving little residue on the sides. This is a good method for small quantities.
The mix was poured into the mould and manipulated around the reinforcement steel and rammed down. I was lucky to have a small electric vibrator to assist in packing the material down. Otherwise a small tamper could be used to pack it down, when nearly finished I used a metal screed to level any high spots.
The calculated mix was exactly the right amount! That does not happen very often.
The finished surface of the aggregate was a little rough for my liking. Therefore I finished off with a coat of the Gel coat material used previously.
The Epoxy sets in 24 hours and is full hard in a week. As soon as it hardens and the mould is stripped I will post a photo.
The next step is the end plates and motor support.
Cheers
Edited By John McNamara on 30/05/2011 17:21:28
The casting process is no different to working with cement. The aggregate mix of 5-8mm graded aggregate, ideally rounded pebbles and washed silica sand for the base and coarse washed silica sand only for the end plates is mixed with approximately 9 – 12 % Epoxy by weight. Ideally less is better. This week I take delivery of the epoxy I have chosen to test. I will report back my findings………………
Hi All
Hi John Stevenson
The base was cast upside down hopefully the top which is now the bottom will have a smooth surface. For this test I applied a gel coat first to hopefully get a fine finish.
The sides were stripped this morning; I found that the gel coat does give a good finish. Lamentably there are a few flaws where the aggregate has disturbed the coating. Not really a problem as I intend to paint the casting anyway. A bit of Epoxy patch will fix the blemishes.
Next time I will leave the gel coat longer time to set, before pouring the aggregate mix.
My biggest issue is getting the right release agent. I had thought that the mould may not survive the pour. I was right, sides stuck in places and I had to chisel them off. I used PVA glue diluted with water as a mould release. Surprisingly this was recommended by a fiberglass boat builder who uses it commercially. It worked very well (Where it worked) I suspect the problem is that the gel coat was applied by brush. It is very thick; I may have removed some of the release agent in applying it. Ideally the release and gel coat should be sprayed on. Today I will try to source a non silicone commercial product. I want to paint the casting, silicone will make that very difficult.
On the aggregate: Inspection of the areas where the gel coat was damaged suggests that more sand will be required. However this base is very sturdy rock solid in fact…. it will be fine for the Worden.
Hi Terryd
The gravel used was 7mm screened and washed river sand, hence the rounding. 8 dollars a bag from a local supplier, the 7mm gage is about the average of aggregate used by the many papers I have read as background for this project. Some papers also refer to rounded pebbles.
I have also located a quarry about 100km away that mines granite and supplies 5mm sharp crushed material.
Sand alone would be ideal for small items. I will be using sand for the Worden end plate castings.
There will be no cracking. Once set the epoxy is almost inert. Few solvents will touch it.
This is where Portland cement fails in this application. It continues to shrink over many years and you will get cracking.
Re casting accuracy: I was referring to conventionally moulded cast iron not Aluminium castings, by conventional I mean greensand castings. Of course today we could also use the lost wax process or a number of others, for large cast objects almost impossible in the home workshop.
Hi Clive yes I want one of those grinders!
My findings so far:
This process works. The mould release issue needs to be settled as does the so called ideal aggregate mix.
However as is, I now have an almost finished base with all fixings in place; a bit of patch and paint and it is done.
When hit with a hammer all I get is a dull clink. The vibration damping is superb.
The epoxy sets hard in 24 hours and can be handled; it does not develop full strength for a week. I plan to check the base for deflection by loading it up on the surface plate after the 7 days has elapsed.
In the mean time there is the end plate castings to work on.
Cheers
Home › Forums › Model Engineer & Workshop › Topics
Started by: Vic
in: The Tea Room
howardb
Started by: Vic
in: The Tea Room
Sonic Escape
Started by: Russell Eberhardt
in: Locomotives
Speedy Builder5
Started by: nevillet
in: CNC machines, Home builds, Conversions, ELS, automation, software, etc tools
duncan webster 1
Started by: Sonic Escape
in: General Questions
Sonic Escape
Started by: Peter_H
in: Manual machine tools
old mart
Started by: old mart
in: Hints And Tips for model engineers
old mart
Started by: Plasma
in: The Tea Room
pmm1
Started by: Chris Raynerd 2
in: Clocks and Scientific Instruments
John Haine
Started by: Greensands
in: Materials
Greensands
in: The Tea Room
Gerard O’Toole
Started by: JasonB
in: Stationary engines
Started by: Clive Steer
in: Electronics in the Workshop
Peter Cook 6
Started by: Nigel Graham 2
Peter_H
Started by: Dr_GMJN
in: Work In Progress and completed items
Started by: david newman 9
Pete
Started by: JasonB
in: The Tea Room
Nigel Graham 2
Started by: petro1head
Vic
Started by: davp1971
in: Help and Assistance! (Offered or Wanted)
davp1971
in: Materials
old mart
Started by: Neil Wyatt
David Senior
Started by: Michael Gilligan
in: Books
Harry Wilkes
Started by: Jeff Swinburn
Jeff Swinburn
Started by: ron61630
Trevor Drabble 1
Started by: Richard Evans 2
Richard Evans 2
