New Memeber in Norfolk, UK
Home Forums Introduce Yourself – New members start here! New Memeber in Norfolk, UK
  • #761082
    petetwissell
      @petetwissell
      Hello all, I am a semi retired design engineer with a background starting in machine shops and progressing through to chief engineer at a large automotive supplier.
      Now working part time as a consultant engineer and volunteering at a local steam museum, a windmill, on the parish council and village hall committee.
      In the time I have available between work and volunteering, I have a range of projects in my home workshop.
      Current projects include a large (2.3 litre) 7 cylinder radial engine, a much smaller 9 cylinder rotary engine, a tilting pedal driven tricycle and a couple of 1950s motorcycles.
      I am a lapsed private pilot. I now satisfy my desire for aviation from building and flying models.
      With every new project, I try to introduce something new that I have not done before.
      I have joined this forum in the expectation of learning from other members.
        Just bumping this up as it was held in the system.
        #765326
        noel shelley
          @noelshelley55608
          Hi Pete, Welcome to the party. You have an interesting range of projects. I have worked in all forms of engineering for 60 years and am also a parish councillor of 35 years. I’m up near Hunstanton. Best wishes, Noel.
          #765328
          Dalboy
            @dalboy
            Hi and welcome. Sounds like you have a full itinerary to keep you busy with your hobbies and volunteer work.
            #765333
            Brian Baker 2
              @brianbaker2
              Greetings Peter, you will find much of interest on this forum, once you sort the wheat from the chaff.
              Brian B
              E Norfolk
              #765363
              bernard towers
                @bernardtowers37738
                from the sounds of your projects theres a lot you could help us with. Welcome Pete. From east Norwich
                #765364
                Harry Wilkes
                  @harrywilkes58467
                  Welcome to the forum
                  H
                  #765405
                  David Senior
                    @davidsenior29320
                    Hi Pete, seems like you have some interesting projects.
                    I also have a background in automotive design, live in Norfolk (a few miles west of Norwich), and volunteer at a museum (Gressenhall). Occasionally I find time to work on a model Le Rhone – but I’ve only got as far as the carburettor!
                    Howard Lewis
                      @howardlewis46836
                      Welcome,
                      You have a number of contacts in Norfolk, and no doubt, others in Cambridgeshire.
                      You will certainly be busy
                      #765748
                      noel shelley
                        @noelshelley55608
                        Just in passing, I had always wondered how the Gnome monosupape worked until in a stroke of luck I spotted the workshop manual in a box of old books at a local auction and got the box for £3. Noel.
                        #765831
                        petetwissell
                          @petetwissell
                          Thanks all for the warm welcome!
                          Re Gnome, my rotary will look like a gnome, but internally I am doing something quite different in an attempt to make a small but practical engine for a flying model. It is very much in the experimental stage – I am building a single cylinder non-rotary to prove some of the principles.
