The question has been asked before on the forum but I couldn't find the answers!
This would be my beginner list for a lathe, in order of importance:
A good book, Sparey is my favourite even though it doesn’t cover modern developments like carbide. Get Neil’s ‘The Mini-lathe’ as well.
Hacksaw and vice fitted to bench.
Bench or stand for lathe
Set of HSS Tools or Set of carbide index tools. Don’t buy fixed carbide tipped tools. This HSS set contains a reasonable selection, beware of sets with odd combinations you may never use.
1x Right Hand Knife Tool
1x Left Hand Knife Tool
1x Chamfer Tool
1x 60° Thread Cutting Tool (Metric & US Threads)
1x 55° Thread Cutting Tool (Imperial)
1x Parting-Off Tool
1x 60° Internal Thread Cutting Tool
1x Boring Tool
A thin 6” metal rule or steel strip, (nipped between tool and work to indicate centre-height)
Metal strip for shimming tools to correct centre height. (Scrap is fine)
A selection of known metals to practice on. Avoid scrap and DIY store metals!
Tin of WD40 or paraffin for cutting Aluminium.
Digital Caliper (Not necessary to spend big money). Later a Micrometer
A DTI, plunger type plus magnetic stand. Later a lever type DTI as well.
Tailstock drill chuck and twist drills to match.
Bandsaw – not essential but you will soon get fed up cutting stock by hand with a hacksaw. This is my single most appreciated tool.
May require:
Taps and Dies with handles etc.
Reamers
Selection of Boring Bars
Rear Toolpost
Clamp type Knurling tool
A few comments on HSS vs Carbide Indexed tips. HSS is cheap, and gets a good finish, and is well suited to slower lathes but you have to grind it to keep it sharp. Carbide indexed inserts are convenient (including no sharpening) but more expensive to get started. They also like to be driven hard to get good results, which may not be possible on older machines. In hobby use they are harder to get good results from than well-sharpened HSS, but much easier to set up and change. You don't need a bench grinder, and most metals can be cut dry – no cutting fluid required to protect the HSS edge. An interesting HSS alternative is a tangent cutter and tool-holder as advertised by Eccentric on this site. These can do a wide range of cuts with a singe simple tool that's easy to sharpen. Don't have one myself, but they are well liked.
Likewise sets of tools vs buying individual tools as required is controversial. Chaps who know what they're doing understand sets usually contain tools that they will never use. Also some sets come with peculiar selections of duplicate or unusual tools – a waste of money. For good reason, they're dead against sets. However, for a beginner, I see sets as a good way of getting started and learning enough to join the 'Chaps who know what they're doing'
The good news is you don't have to have everything ready on day one. I'd guess most of us have bought a high percentage of our tooling as and when needed. The internet makes it easy to get stuff.
The thing that caught me out on day one was not having anything to shim tools to height. You need a selection of thin metal strips of various thicknesses to fit the toolpost. Very low tech and deeply frustrating if you have to make them by hand from a poorly stocked junk box. For fine adjustments you can cut shims from aluminium cans. I mainly make shims from the steel metal bands used to secure packaging, but these supplement a number of thicker blocks cut to shape and size on a mill.
Edited By JasonB on 20/01/2019 13:14:28
