Welcome!
The Forum will almost always have someone who can help ypu if youy have a problem.
It will be worth buying some books.
You will find a set of Zeus Charts invaluable, (I still use mine, bought in 1958! )
there are lots of books on lathes.
L H Sparey "The Amateur's lathe" was, for years, the "bible" It wa written when many model engineers ownws and use Myford ML7s, but the basic principles are the same for any lathe.
ian Bradley, "The Amateur's Workshop" deals with a workshop inbn general, but covers one or two points of setting up a lathe that Sparey does not.
It is important to that a lathe is correctly set up, especially without twist in the bed, if it is to work properly.
Other books to consider are
Stan Bray "Basic Lathework"
Harold Hall "Lathework"
Both are former Editors of Model Engineer''s Workshop, as are David Clarke, and Dave Fenner who have both written books about the mini lathe.
The current Editor, Neil Wyatt has written a book on lathework, based on his experience withe the Sieg SC4, (and the mini lathe..
You might find Tubal Cain's "Model Engineer's handbook" a useful reference book. (I do! )
But the basic principles are the same for nearly all machines; there will be detailed differences depending how the machine is configured.
FWIW become familiar with your lathe, how to grind tools and set them. Making simple tools help to gain experience and confidence, and provide tools that you can use for years afterwards.
My hobby horses are: Centre Height Gauge, Tap Wrenches, Die Holders (Especially the sliding Tailstock ones. )
When you acquires a 4 jaw independent chuck, you can make a spare centre, which will help centering work in it, by the Two Centres method, and a Mandrel Handle.
Eventually, you might make a Sliding Tailstock Tap Holder.
With a lathe, you have the means of making all sorts of things.
Enjoy!
Howard..
