Welcome!
You will always find help on here.
Try to find a Model Engineering Society,local to you, and join. You will find like mindeed folk, advice, help and possibly face to face demonstrations.
Since you are relatively new to lathework, may I suggest buying at least one book?
Firstly, you will find as ert of Zeus charts very useful.
You have a choice of books to choose from.
The "bible" has been L H Sraey "The Amateur's lathe" (Old and based on the Myford ML7 but still sedts out the basic principles.
"Basic Lathework" by Stan Bray
"Lathework" by Harold Hall (Both former editors of Model Engineers' Workshop)
Neil Wyatt (Curreent Editor ) has written a book on lathework, based on his experiences with a mini lathe and a Sieg SC4.
The March issue of MEW contains part 1 of "Notes for Newbies", which you may find helpful.
Now that you have a lathe, you will need, if you have not already got them, a bench grindedr (For sharpening HSS tools ) and measuring equipment
Minimum should be a 62 (150 mm ) calliper, Vernier, dial or digutal; take your choice.
If you have a 4 jaw chuck with the lathe, you will need a magnetic base and at least one DTI.
That will allow you to centre work in the four jaw, more accurately than in a 3 jaw (A good 3 jaw will probably hold concentric within 0.005" (0.127 mm)
The 4 jaw will also allow you to hold square, octagonal or irregular work, and if needed, deliberately set work off centre.
Gain experience of the machine, and confidence by doing small jobs. make small tools, A Tap Wrench? You will find a Centre Height Gauge useful, and a time saver; although we are no longer on piecework!
A Mandrel Handle is handy for cutting threads up to a shoulder or down a blind hole. Saves broken taps or stripped threads!
HTH
