I did wonder when you would all start to get cross.
Ady1, thanks for that, it is a good tip
Ian P, there is a space at the top for a banner ad, which isn't ready yet. The space at the sides is as it was previously
KWIL, I'm sorry that you don't like latest posts being at the right, but I don't think there is much likelihood of this changing to the left.
Roy, I understand what you mean, but you will get used to it quite quickly.
Versaboss, if the black links are very offensive to you, I can change them to blue
Ziggar, nothing has changed this morning that could have affected your digital access, are you using the correct link. Your magazines can be found by using the white 'Magazines' link in the green bar at the top. If this doesn't work for you, then there must be a separate access issue and I will investigate it for you
Edited By Katy Purvis on 30/09/2013 14:59:44
