Well, we had a truly enjoyable afternoon at Brian's place, playing with his lovely new lathe. As is usually the case, the big problem was really an accumulation of small variances. Both in equipment and operating procedures, as Brian has said.
The biggest contributor was a revolving tailstock centre that was not staying on centre. In fact, initial DTI reading revealed 0.30mm up and down movement at the large diameter of the centre itself. Hmm. A bit of exploration found a hitherto undiscovered tailstock quill clamping Allen screw on the far side of the tailstock body. Nipped that up and things improved drastically. But still there was 0.20mm up and down movement measurable at the centre.
Turns out (no pun intended but all kudos accepted) the MT1 taper was a gnat's bicycle too small for the hole in the tailstock. So the taper was not seating. Instead the unmachined shoulder at the large end of the taper was hitting the tailstock quill and allowing the whole centre to flop about loose. Solution: chucked up the centre body and machined off the shoulder so the taper could seat properly. The lathe does its first ever piece of useful work and fixes its own problem. For now. DTI is showing just 0.02mm movement at the centre. Quite acceptable and about as good as you are going to get it with ball bearings that always have an internal clearance of maybe that much.
So we whiled away several pleasant hours then with a bit of tutorial on general lathe work, locking the cross slide, and so forth, and testing speeds and feeds on some sample pieces of ally and steel. All were turning quite nicely. Feed rate was measured and confirmed at 0.05mm per mm and giving a nice finish. We found the spindle high range speeds (300 to 3,000 rpm) was a bit hard to finely judge the exact rpm in the lower range. So we changed it to the low range, 150 to 1500 rpm and found much finer control over the rpm. A digital tacho would be real handy.
BUT THEN … we stopped for a cuppa and a chinwag. When we went back to the machine with a view to trying out some of the carbide toolbits etc the bloody thing was turning rough as guts again, chattering and squealing its head off. Great diagonal striations across the surface. Same pieces of material, same toolbits, same speeds and feeds. And nothing we could do seemed to make any difference.
Put the clock on the tailstock centre again, and found 0.20mm movement again. WTH?? This time it seemed the bearings had heated up and got looser. Put the dead centre in, nipped it up just so and all was good again. Problem solved!! Turning beautifully on ally and steel, and taking up to 1mm cuts on either, with both HSS and Carbide tools. Problem Solved!!!
Partly. The other part is that the headstock spindle had some measurable movement at the chuck mounting flange. No endfloat, but about 0.02mm at the flange with some gentle hand pressure on the end of a 100mm long bar grasped in the chuck. Not bad, for a spindle running on ball bearings that by nature have internal clearance. But by pushing with my fingers on the end of the 100mm long bar about as hard as I could, it was easy enough to get a reading of 0.08 or even 0.10mm at the chuck flange.
For us old duffers, that's three to four thou of spindle movement. Certainly more than I would like to see on the larger lathes I am more familiar with. But having no experience on these small lathes, with their small diameter spindles and light-on cast headstock and bed, I am not sure if this sort of movement is normal? IT could not be felt as "slop" but could have been some flexing of the spindle and bed/headstock unit? Perhaps those more experience with mini-lathes can enlighten us on that one. (Neil??)
I have seen on the ARCEurotrade site that with some of the Sieg small lathes, many owners choose to replace the standard ball bearings with angular contact bearings that can then be run with a small pre-load and therefore zero effective clearance. So perhaps the problem is the plain ball bearings? I know from experience that Chinese bearings can sometimes leave much to be desired compared with a good brand name such as SKF etc. Perhaps someone with mini lathe experience can comment on this?
So it seems that for any work more than 25mm from the chuck, the tailstock centre is essential for stability to stop the headstock spindle movement/flex etc getting out of control. So for most work, it is good enough. A fixed steady would be helpful for long jobs that can't take a centre, such as boring a long cylinder etc.
But as it stands, using the dead centre, the lathe performs beautifully for a little unit of its size and type.
The pre-ground HSS toolbits seem to work ok when fresh and sharp. The Hopper-ground toolbit likewise. There was a bit of trouble running in the high speed range and knocking the edges off, but using the low range and careful control of speed cured that. I am not sure the speed increase is linear per graduation on the control knob so care must be exercised (or digital tacho fitted!)
Overall I think Brian is pretty happy with the machine now and was turning away like a champion on the test pieces.
He is going to buy a better quality MT1 revolving centre. The one he has now is a "light duty" job. It does not have the screwed plate on the front of the body that allows large bearings, something like a 6203, to be used. It does not appear to have any bearing retainer visible, so I can only conclude that it is a solid lump with hole up the middle about the same diameter as the OD of the actual centre. IE about 16mm or so. So the bearings must be tiddlers of 16mm OD and perhaps 8 or 10mm ID. Not at all up to the job. The centre was an internet cheapie, not part of the lathe kit itself.
