New ELS-fitted Lathes from Amadeal
  • #793297
      Electronic lead screw (ELS) systems are becoming increasingly popular. Readers of the next issue of ME&W will see that Amadeal’s advert features a Weiss lathe with an ‘electronic change gear system’ i.e. an ELS.
      Apparently the ELS version of the 210 lathe has been popular, and now EL250, EL550 and EL750 machines with a 38mm spindle bore will be arriving at the end of May.
      We hope to carry some more information on these machines in the magazine soon.
      Bazyle
        @bazyle
        Surprised it has taken so long. They found a variable speed motor was cheaper than back gear years ago so now have saved on change gears while adding versatility. I wonder if it does BA threads as I have just been compiling a table of changegears for a friend’s EXE lathe.
        Leadscrew is next to go as a stepper on the saddle engaging the rack will save on threaded rod.
        As an aside since some will say the rack is not ‘precision’; in industry since microprocessors became common it has been normal to compensate for errors with a table of errors after a calibration process. This has enabled laboratory grade standards to be moved into the workplace, especially in electronic measuring instruments since the early eighties.
        #793322
          It is just a case of entering TPI or Pitch so BA should not be a problem.
          #793409
          simondavies3
            @simondavies3
            One of the best things I did to my lathe a couple of years back when I fitted Clough42’s version of an ELS.
            Now I don’t think twice about cutting a thread, whereas in the past it was weighed up against the hassle of assembling the change wheels then dismantling and returning to the auto feed setup.
            Simon
