On
20 May 2024 at 15:07 carlw Said:
… The problem with optos is that the mounting of the pendulum allows it to move at right angles to its swing and a vane could contact the body of the opto. This appeared to be serious problem when starting the pendulum from stop as I had no way of starting it in the correct plane. I have since found a work around which may allow me to use the optos.
Chris: I am probably less well up on electronics. I’m struggling to unlearn power on-off and learn to think in TTL’s sorta on and sorta off. My knowledge of HEDs is also limited. My magnet will be a 1/8″ NIB which will have a rather small attraction to the steel in the HED.
I see some experimentation in my future.
Carl
Carl, I hesitate to offer advice because building a Wilding clock means you’re a step ahead of me, at least mechanically. However, what you’re doing has some common ground with my experimental high-accuracy pendulum clock project, which might help. Ought to mention the clock comes with elaborate ways of measuring short and long-term pendulum performance: each beat of the pendulum, in so far as my opto-sensor system can be trusted, is timed to within about half a microsecond
My Mark 1 pendulum consisted of a steel bob hung from a thin carbon fibre rod, with no suspension at the top. Instead the carbon-fibre rod flexes like a spring leading me to call it a ‘sprod’. Consequences:
- The build is extremely simple
- The pendulum’s period is not predictable using either the simple or compound pendulum formula. (Doesn’t matter in my application.)
- Although the carbon-fibre rod has excellent temperature stability, the resin matrix turns out to be humidity sensitive. Humidity alters the springiness of the rod and hence the timekeeping, a problem!
- Having a round rod with no constraint means the bob need not fly straight, instead following some ellipse, the period of which is unstable.
Although the elliptical path followed by the bob tends to straighten out, the bob’s flight path is disturbed by every impulse, and also by any vibration or air moving in the building. Like your clock, starting the pendulum was a easy enough except it took over an hour for the period to stabilise. For that reason, I’ve replaced the ‘sprod’ with a conventional flat-spring suspension, which greatly reduces the bob’s tendency to fly ovals. The spring would also reduce the chance of a vane hitting the sensors.
If there’s room inside the clock, also possible to move optical sensors further apart. Unlike Hall Effect Devices, which typically only react to a very local magnetic field, an opto-sensor system will work over several metres if need be.
There are two basic types of HED, analogue and digital. The analogue type measure magnetic intensity, which isn’t needed in a clock. The digital type are more useful in that they switch instantly from OFF to ON whenever the magnetic field level passes a threshold. This makes them good for timing applications like tachometers and clocks.
I know what you mean about learning TTL. Actually, TTL and power control aren’t that different. Conventional power control usually turn some device on or off with a system of mechanical switches, mainly manual, but also automatic such as thermostats etc. Whilst mechanical systems were traditionally used to implement the rather complex logic required by traffic lights, washing machines, or CNC tools, it’s much easier to build the control circuitry with digital logic (TTL). The electronics can be packed at high-density on to a low voltage printed circuit board. The electronics send low voltage control signals to the distant big-iron, with many advantages such as no need to run lots of separate power cables between the brain and the muscles. These days discrete logic systems built with TTL are rare, because it’s often cheaper and easier to program complex logic than it is to build the same function from integrated circuits.
Although digital electronics are always ON, their outputs are always ON/OFF signals. So rather than a human pulling a lever to operate a switch, the lever is pulled by a solenoid actuated by a TTL signal.
Welcome aboard – pendulum clocks are fascinating.
Experimentation galore – my clock is nothing but. Got it tantalising close to working as intended but so far no banana! There’s always some new problem to fix!
Which ME was your Hipp article in? I’d like to re-read it.
