My stepson found this tool in a box of various items he had from an ex-plumber.
A knurled, spring loaded nut at the top allows adjustment and locking of a cam which varies in thickness, numbered 4 at the narrowest and 12 at the thickest setting. The higher numbers are closer together.
Pulling the lever presses a spring loaded anvil with a slot in it against the cam, then a wedge or blade rises up in the slot against the cam as well.
There are marks inside the handle, but all I can read is “Made in England”.
I immediately guessed it was a wire stripper, but this theory falls down as (1) you need to pull the wire the wrong way and (2) stripping anything other than a small wire needs the strength of Samson. The reason is that it works there wrong way for a stripper where the centre should be a sprung part to grip the wire, and the outside parts should be the blade forced up to cut the sheath.
Can anyone shed some light, noting the possible plumbing connection?
Thanks
