Myford VM E or F Table Gib strip
Home Forums Manual machine tools Myford VM E or F Table Gib strip
  • #710701
    Tony Bradley 1
      @tonybradley1
      Hi all,
      does anyone know where I can get a Gib strip for a Myford VMF or VME Mill ?.
      I think the VM-F and VM-E use the same Gibs on all ways, I’m particularly looking for a Gib for the Table or ‘X’ axis.
      I’ve tried everywhere that I know including the Warco equivalent from Warco,
      Thank you
      Tony
      Harry Wilkes
        @harrywilkes58467
        Hi Tony
        Have you tried the Myford Lathes group ? Someone on there may be able to help.   https://groups.io/g/myfordlathes
        H
        #710718
        Tony Bradley 1
          @tonybradley1
          Thanks Harry, I’ll give it a go.
          Tony
          #710726
          Diogenes
            @diogenes
            ..FWIW – don’t know whether the Chester ‘830 VS’ mills are a direct dimensional copy but they certainly appear to owe something of their make-up to the VME – and they are a still-current model.
            #710742
            noel shelley
              @noelshelley55608
              It should be possible to make one with a length of BMS if it’s an ordinary gib strip. If you can’t use the mill it could be filed ? Noel.
              #710744
              Tony Bradley 1
                @tonybradley1
                Thank you Noel, I have already made the column gib and I have a Cast Iron gib that I can modify for the table but I was looking for a direct replacement in case it goes wrong. Its a tapered gib so I machine that with a sine table on my Downham Jig Borer, the only tricky bit is the travel on the Downham restricts the length I can machine, so I’ll have to do it in two halves. Thanks for the suggestion thou.
                #710745
                Tony Bradley 1
                  @tonybradley1
                  Thank you, I’ll give Chester a call tomorrow
