Go for it!
My VM-C and Harrison L5 keep each other company very happily!
The one thing it isn't, is as it was apparently advertised new, a "turret" mill. The head can be tilted in one plane, but is of fixed radius.
Yours having a DRO installed is a bonus. I treated mine to a Machine-DRO 3-axis set, which was not easy because the milling-machine was not designed for simply bolting such things straight on; and I had to sacrifice the long-travel stops to fit the scale and reader. (Some would aver I no longer need them, but I disagree.)
I've also treated it (and the lathe) to a Newton-Tesla 3-phase motor etc but still use the belt-drive on the mill (and the lathe's headstock gears) as the speed-range on the electrics is not sufficiently wide for many operations. The conbination gives a fine-&-coarse range, keeps the torque-multiplier and keeps the motor happily fast at low spindle speeds.
The one drawback is that when using diving-heads, rotary tables etc the cutter headroom evaporates, but this is probably true of most medium to small milling-machines.
Milling-machines sprawl! The width it occupies is the table length over both of the handles, plus its long travel, and symmetrical with the column – but don't forget you need space to turn said handles; and to be able to reach the space round the sides generally.
Also think about head-room above the machine. You need clearance to open the belt-guard fully, when it stands upright on its side.
Exanine the swinging-arm that carries the belt-drive's idler pulley. If its fulcrum works loose the arm can flop about, making the drive noisy and not doing it any good. It is easy enough to re-tighten but remember it is tapped into an aluminium-alloy casting.
I've not found the lack of a fine down-feed a problem. I work around it easily enough.
The two problems I do have with my VM-C are both quill-related, though.
– The quill is so stiff the return-spring won't return, making sensitive drilling rather fraught. Despite studying the drawings in the lathes.co fasimile manual, and asking for help on here, I have found no obvious way to investigate and rectify it. The rack and pinion and the axial bearings might simply be bunged up with congealed grease, but are all inaccessible.
– It is sometimes very difficult to engage the R8 tooling correctly. I do not know if the spindle has a pin or a rectangular key but it seems either damaged or loose. That inaccessibility leaves it an irritating mystery; but a touch of oil on the collet's key-way helps.
Obe good point though, I found serendipitously I could make a self-ejecting draw-bar; having lost the plain draw-bar that came with my second-hand mill. The sectional drawing suggested as later proved, the spindle has a break of internal diameter allowing an ejecting draw-bar to work. I don't know if that was in fact the original idea.
