Myford Thread Dial Indicator Plans?
Home Forums Workshop Tools and Tooling Myford Thread Dial Indicator Plans?
  • #53820
    _Paul_
      @_paul_
      I am interested in making my own Indicator with a larger than standard dial (suit my poor eyesight).
      On the face of it it seems to be a relatively simple item to construct; my idea so far is to machine a lump of round aluminium stock for the case/mounting turn a BMS shaft then make the dial & drive gear from Brass.
      Making the drive gear should be interesting my plan is to mount/index it in the shaper and cut on a slight? angle.
      My question then is where might a chap find/purchase plans for home made versions of the above, do they exist even? searching this site and a general “Google” has drawn a blank so far.
      Paul
      Edited By Myford_Paul on 25/07/2010 09:38:32
      _Paul_
        @_paul_
        #53824
        AndyB
          @andyb47186
          This is a link to a Google book article on the subject.
          You will have to work out your own gear size; it doesn’t stipulate which lathe it is for though, in the picture, the tool holder points to it being American (South Bend?)
          #53827
          Gone Away
            @goneaway
            Unless you want to make your own gear for aesthetic reasons, you could probably use a standard spur gear of the right pitch. There’s no load on it so the exact tooth form is not that important. It just has to move one tooth per rev of the leadscrew.
            You could possibly find a suitable worm gear too but that might be a bit fussier.
            Edited By Sid Herbage on 25/07/2010 17:40:33
            Edited By Sid Herbage on 25/07/2010 17:42:51
            #53840
            _Paul_
              @_paul_
              Thanks gents,
              The google book article is good.
              I was toying with the idea of making the drive gear from Nylon/Delrin.
              Paul
              #53855
              Keith Wardill 1
                @keithwardill1
                Paul,
                There is already some stuff in this ME Forum on Thread dials which might be worth a look – enter ‘Thread Dial’ in the ‘Search For’ box at the top of the page.
