Myford T Slot size and suitable cutter
Home Forums Workshop Tools and Tooling Myford T Slot size and suitable cutter
  • #16803
    Binbag
      @binbag
      Binbag
        @binbag
        Hello;
        Can someone let me know out there what is the correct size of the myford T slot on the cross slide and vertical slide and also what is the correct cutter to use to replicate said T slots.
        I want to make a cross slide attachment to take my vertical slide.
        Thanks
        Ralph
        #89286
        John Haine
          @johnhaine32865
          #89287
          Binbag
            @binbag
            And 61 seconds reveals 2 different sizes qouted in other articles. So what I am after is the correct and complete dimensions not just width.
            Plus what is the suitable cutter.
            #89289
            NJH
              @njh
              Hi Ralph
              You might try here
              I will measure my crossslide tomorrow
              Norman
              Edited By NJH on 17/04/2012 22:57:23
              #89291
              MICHAEL WILLIAMS
                @michaelwilliams41215
                Width :
                Basic slot 3/8 .
                Lower slot 5/8 .
                Height :
                Upper slot 7/32 .
                Lower slot 5/32 .
                All in inches .
                There never seems to have been any formal tolerance system but roughly speaking T slot is dimensioned for a loose fit on nominal size T bolt and T bolts themselves are made undersize .
                Many detail variations can be found on actual measured dimensions of slots and bolts .
                At least one lathe has been found with dimensions of slot which measure 10 – 16 – 6 – 4 mm
                T slot dimensions originated from an available Woodruff cutter many years ago These cutters are still available from several sources – try Hemmingway , Tracy Tools and RDG .
                #89303
                MICHAEL WILLIAMS
                  Text editor stopped working last night when I was tidying up above post and then would not let me back to edit .
                  Corrections : Lower slot is actually specified as 9/16 inch min but in practice some are wider up to 5/8 inch.
                  All cutters ever seen cut a little wide anyway when new .
                  Suggest you take 9/16 inch as the proper working dimension .
                  All other information in above post seems to be correct .
                  #89314
                  KWIL
                    @kwil
                    Proper T Slot cutters have a cutting face, top and bottom as well as periphery. You can use woodruff key cutters ( I have, for Myford sized slots), very carefully. Try also Sussex Tools, if not a stock item they can obtain from UK manufacturers.
                    #89316
                    S.D.L.
                      @s-d-l
                      Posted by MICHAEL WILLIAMS on 17/04/2012 23:23:23:
                      Width :
                      Basic slot 3/8 .
                      Lower slot 5/8 .
                      Height :
                      Upper slot 7/32 .
                      Lower slot 5/32 .
                      All in inches .
                      That would make it 3/8 sloting cutter first then 5/8 * 5/32 Woodruff cutter
                      See Here
                      http://www.buckandhickman.com/find/category-is-CT+Cutting+Tools/category-is-CT03+Standard+Machine+andToolroom/category-is-CT0303+Milling/category-is-CT030306+Woodruff/product-is-026691
                      Steve Larner
                      #89323
                      Binbag
                        @binbag
                        Excellent – thanks everone. I have ordered the cutter and will be making swarfe very soon.
                        Cheers
                        Ralph
