Myford Super 7 Tufnol gear studs
Home Forums Manual machine tools Myford Super 7 Tufnol gear studs
  • #14392
    Leon Vorster
      @leonvorster67773
      Leon Vorster
        @leonvorster67773
        Hi Everyone, I've checked the forum and googled a abit and I am a little stumped. How does one remove the tufnol gears (HeadStock Assembly: Part 35, 46) ?
        Any help would be greatly appreciated.
        #569991
        Tony Pratt 1
          @tonypratt1
          Looks like the gear stud [35] is a press fit in the tumbler reverse lever [55]
          Tony
          #569993
          Leon Vorster
            @leonvorster67773
            Okay I did find some related posts after all. So it seems I need to remove the entire Tumbler Reverse Lever by removing the grears then removing the Tumbler Reverse Locating Screw and then I take it I would need to apply some force to the rear of the studs to pop them out …. does that sound about right ?
            Edited By Leon Vorster on 05/11/2021 18:25:46
            #570001
            KWIL
              @kwil
              You can remove the entire cluster, first remove the locating screw and then it just pulls away with the gears still on. Indedd the studs are a press fit.
              #570512
              Leon Vorster
                @leonvorster67773
                Posted by KWIL on 05/11/2021 19:06:51:
                Thanks KWIL I managed to get them out.
