Simon,
Thanks for that chart, no doubt it will help other users of the early gearbox's but only if they can do a 30 /17 and 29/16 cluster.
I went back and examined the 14.5 and 20 degree differences.
Quite a difference. The one on the right is 29T corrected but at 20degrees PA with the original No 4 cutter at 14.5 PA superimposed. As you can see nothing like.
The one on the left is using a No5 cutter 21T to 25T range and cut 0.0065" deeper. Again loads of under cutting but the flanks are a good match.
