Hi Guys, a newbie here, I’m looking for some advice/tips from any experienced Myford experts.
I have a Super7 fitted with an early Mk1 QC Gearbox # 2281 (short lead-screw driven from right hand side of gearbox with three external gears)
The gearbox selector internal tumbler gear is damaged so needs replacing, I believe this tumbler gear is the same as the later MK2 gearbox (39 teeth) can anyone confirm this?
Consequently I have few questions.
Do I have to completely remove the gearbox from the lathe in order to get to the tumbler and replace it?
There is very little access so do I have to remove the other gear clusters as I cannot even see how the tumbler gear is held to the selector shaft?
Would it help just remove the top set of gears?
Any tips on stripping the gearbox and pitfalls to avoid?
I have downloaded the gearbox manual from the files but it appears to be for the MK2 Gearbox and does not give information of how to access and replace the tumbler.
So if any of you guys have replaced the tumbler I would appreciate any insight and tips on tackling the job.
Thanks in advance for any help and sorry for long post. Regards Brian.
