Myford Super 7 Leadscrew
Home Forums Beginners questions Myford Super 7 Leadscrew
  • #10487
    John Button 1
      @johnbutton1
      John Button 1
        @johnbutton1
        What should be the optimal end float for the lead screw please? I have recently bought this lathe with end float measuring 2.7mm/0.106 inches. If this gap requires adjustment any help would be appreciated.
        #500465
        Tony Pratt 1
          @tonypratt1
          As little as possible without binding,I can't see it being critical but 2.7 mm is a hell of a lot of end float.
          Tony
          #500466
          Alan Donovan
            @alandonovan54394
            Hello
            2.7mm end float is far far too much. It should be approaching zero mm and ‘free to rotate’, not clamping the lead screw.
            I do not know enough about S7s to advise you what to do exactly, but someone else will. It would be useful to know if the machine is fitted with a quick change gearbox, and also provide photos of the bracket / lead screw arrangements at both ends of the lead screw, if that is possible.
            Best regards.
            Alan
            #500468
            David George 1
              @davidgeorge1
              Hi John welcome to the forum. Is the actual leadscrew moving or is the saddle moving when engaged. If the leadscrew is not moving but there is that much play in the nut it needs replacing.
              David
              #500479
              Martin Kyte
                @martinkyte99762
                Posted by David George 1 on 10/10/2020 08:35:38:
                David
                Or at least adjusting
                regards Martin
                #500502
                Nick Hughes
                  @nickhughes97026
                  Discussed before here:- **LINK**
