What does ‘service’ mean? There is nothing much on a Myford you can’t, or don’t do yourself, on almost a weekly basis if the lathe is in regular use. Ensure lubrication, adjust gibs, check belt condition and tension etc. What else would/could a ‘service engineer’ do unless the rear spindle bearings are completely shot, which is hardly likely.
