What sort of noise?
Super 7’s are prone to noises and vibration from the primary drive. A worn belt can produce a clattering noise, as can a motor, countershaft or spindle pulley that is not tight on its shaft. I even have different belts for high and low range hanging on a nail near the belt guard. The link belt is quiet in high range but too stiff to go nicely round the motor pulley in low range. I have recently bought a ZX section belt for low range, where it is quiter than a not very old Z section belt, but both are noisy if used in high range.
I am asuming the ‘modern’ bronze/iron cone clutch. If the clutch squeals when engaged (particulary in the top two speeds) it wants a bit of light oil on the cones. Check the clutch lever has a little free play when the clutch is engaged.
Be careful if you have to let the big spring out if its cage, it is quite fierce and may bite. If memory serves you can get at the pulley bearings from outside, but you would have to let it out if the thrust bearing needs attention. In withdrawing the countershaft don’t forget all the circlips and keys that have to be removed, some rather a pain to get at.
