KWIL.
Thanks, yes you have identified one of the right parts on my machine. The offending part at this stage seems to be LA28, it appears to be bronze, it has obviously been rotating but both the front and back of the washer are nice, smooth and shiny. I am not clear what you mean by 'spacer' but my LA28 is definitely a thrust washer.
My list ends at LA49 but the circlip spacer for the leadscrew half of the mating bevel gear is not listed. That part appears to be a fairly hard steel.
Perhaps the machine has been modified and the thrust washer LA28 is now listed as a spacer and maybe even a different material?
Please can you describe what your LA28 and LA50 look like. Perhaps yours is a slightly later machine with a 'fix' to prevent the jam?? Also, you have got up to LA57!!! You have got at least 8 more parts than me – I'm jealous.
With the cross slide off, no I couldn't turn the bevels via the leadscrew. The bevel gears were jammed and only freed up when I started removing parts. I had to strip down the bevel stud assembly with its herd of circlips before they freed up.
John,
Thanks for describing that procedure. At least know that there s a common issue out there.but there is no way that a loosening and retightening of the cap screws would shift this particular jam. It really was as tight as a weld until I stripped it down.
KWIL/ Martin,
I didn't take the half nuts off or the rack and pinion assembly gears – perhaps I should have called it a partial strip down. I stripped the parts associated with the bevel gears and kept removing parts until the gears unlocked. That included the cross slide off, the leadscrew removed off the machine, the apron off the saddle and both bevel gear assemblies removed.
Phil H
