In the absence of any further responses and now having completed the saddle stop I am able to offer the following information that may benefit others in the future(?). This applies to the installation for my long bed Super 7 with power cross-feed of 1980 vintage and may differ for other machines……….certainly my earlier pre power x-feed machine does vary slightly. There is very limited clearance for the saddle / apron assembly to pass with the T strip fitted due to the proximity of the saddle plate above, the rack pinion shaft below and the apron to the front. Before starting it is necessary to remove the cast alloy leadscrew guard and the blackened sheet steel piece behind it as these will foul the T strip. Once the T strip is fitted the sheet item can be reduced by about 1/16” on its inner edge to clear and a small corner (maybe 1/8” x 1/8” ) cut from the bolting flange of the guard. This does mean the assertion that ‘no modification to your lathe is necessary’ is not strictly true!
The T strip that attaches over the rack was machined from 5 x 12mm BMS strip in lieu of the supplied ¼ x ½” and the width was reduced from the stated 0.455” to approx 0.430”.
The 3/8” was maintained but the 1/8” thicknesses were reduced to approx 2.5mm each – although I erred on making the thickness of the top of the T slightly under and preferring to leave a shade more meat on the lips on the cast iron block.
The holes for securing to the lathe were offset towards the top edge of the strip, thus lowering the strip, by drilling about 12 thou off centre – without this the strip fouled the plate that holds the saddle down on the lathe bed. Note that due to the reduced thickness of the strip you cannot use 2BA cap screws as there is no room for metal under the head! My solution was to countersink and substitute 2BA x ¾” long socket head countersunk screws. As my machine is a long bed I made the T strip about 14” long and span 5 rack screws rather than 3 as per drawing – but note that the pitch of the screws is 3.300” on my machines – not 3.5” as stated on the drawing, though to be fair they do state to use the rack as a drill jig. I didn’t, just relying on the feed screws on my D/W for spacing and all was ok.
The position of the hole, in the CI block, for the brass clamp pads for the tee needs to be relative to the ‘T slot’ not the edge of the block.
The suggested woodruff cutter was no longer suitable due to the size changes and I opted to make my own cutter from 5/16” dia silver steel with a slot across the end and a small scrap of carbide brazed in and ground up – looks a bit like a boring tool. For security I threaded the holding end and used in the autolock chuck and basically flycut the undercuts one side at a time.
Despite taking care positioning the hole for the brass clamp pads for locking the 3/8” dia. bar the centres fell too close and the 2BA cap screw would not fit. The simple expedient was to locally turn the threads off. assemble the pads and screw to the block and then slide the bar in place. Take care – you have been warned!
(Continued in next posting).
Edited By Adrian Dixon on 11/01/2012 21:11:36
Edited By Adrian Dixon on 11/01/2012 21:11:59
