I think that the clutch is a useful addition if you are using the standard single-phase motor – it avoids the starting loads involving the centrifugal switch, starting capacitor and so on. But once we have the three-phase motor that is essential for use with the VFD all those switching and mechanical loads go away, especially with the soft-start capability that comes more-or-less for free with a VFD. I used to have a S7 with its chunky clutch and used it all the time but I now have a lathe with three-phase motor and VFD and start-up is even more gentle via the speed ramp-up.
Coming back to the original question – one of my complaints about the “sealed for life” VFD enclosure would be the inability to see any error codes on the VFD when it does trip out. There have been a few suggestions effectively looking at various overload conditions but there is another possibility that I suffer from in my own VFD. Most VFDs will have a three-phase bridge rectifier at the input, used to charge a DC bus capacitor which then feeds the inverter section that produces the output. This input rectifier configuration is also happy to accept single-phase input and again this will charge the capacitor. However, the three-phase input will charge with a series of 300Hz pulses where single-phase only gives 100Hz charging pulses. Apologies to people with more insight into what is actually happening here but at a hand-waving level it’s about right! When running, the inverter circuitry is drawing charge from the capacitor and the voltage will pop up during each charging pulse but “sag” between pulses. If the charging pulses are further apart then this “sag” will be more pronounced. Generally, if you are running within the VFD’s ratings this should not matter too much but under heavy load, the sag can exceed allowable VFD limits. In fact, in the case of my own lathe and VFD, at high speed just the drag of the machine is enough that this voltage sag trips the VFD protective circuitry and the reason that I know this is the error code that comes up tells me so.
I wonder if this is also the problem reported here?
In my own case, I know why it happens – it is actually a 415V input/output VFD, fed via a voltage doubler from 240V single-phase which means that the charging pulses are only at 50Hz. This allows the inter-pulse voltage sag to be even greater. Fortunately, this only happens above about 2K RPM and I tend not to run at those speeds very much – it’s an elderly lathe and in any case an 8″ three-jaw chuck just looks intimidating at that speed…
