Old thread I know but I found this helpful when I set out on my own version of this project.
As a direct answer to the OP.
I have just completed the fitting of a Super7 headstock (only) to an ML7. It appears to operate just fine and there appears zero difference in centre height. Only minor (approx. 0.5mm) adjustment to the horizontal element of the tailstock was necessary (well within the range of inbuilt adjusters).
I have retained the ML7 motorising unit (a cost saving necessity) so, for now at least, will have to live without the headstock cover. Otherwise (and subject to further testing and measuring) a straight headstock swop is valid.
If anyone is interested in hearing about the outcome of "further testing and measuring" I am happy to post further otherwise my work here is done!
Hope my experience (in this instance) is of some use.
Regards.
Frank C.
