Ever since I got my S7 new I've religiously topped up the oil cups on the countershaft bearings. I noticed that the RH cup was always empty, but the LH always appeared to be full. Today for the first time in ages I used the high speed range and it was even noisier than it used to be. Now I wonder if the LH oil cup is actually feeding much (any?) oil to its bearing?
Can anyone tell me how they are fixed in position please? I'd assumed they are screwed in, but looking closer each one sits in a slight recess in the bearing housing and it certainly looks as if the cup itself would foul on the sides of the recess if one tries to unscrew it, so maybe they are push fit? I'd like to remove the oiler and just verify that oil is getting through to the bearing.
Why on earth would Myford still fit sleeve bearings in this position rather than a couple of ball bearings, in a lathe manufactured in the 1990s?
Regarding the noise, on the high speed range the lathe starts with an almighty jolt with the clutch disengaged and then runs with a bit of a rattle, then just gets noisier when the spindle is going. Smooth and quiet it has never been!
