Could anyone familiar with the Myford S7 help with a sanity check?
I would like to move the motor-drive belt-guard backplate a few millimetres further away from the countershaft mount (to suit a new 3-phase motor, the shaft of which is slightly short).
Have I understood correctly that the whole cone pulley and clutch assembly can be withdrawn without dismantling the clutch if I remove the grub screw from the cone pulley and the circlip next to that pulley? I could then introduce a couple of spacer washers behind the backplate.
