Myford quick tool post problem
Home Forums Workshop Tools and Tooling Myford quick tool post problem
  • #112926
    David Brown 5
      @davidbrown5
      Hi
      Got my new Genuine Myford quick change tool post with some Genuine Myford tool holders, my problem is there is movement on the guides when it does up therefore allowing the tool holder to be locked in slightly different positions altering my tool hight by about .5mm , i have tried all the holders and they are the same? it would apear the clamping plate that pulls the holder in is pulling in tight before it has properly lockated on the v guides alowing me to very slightly rock the holder on the v guides, has anyone else noticed this. hope this makes sence.
      David Brown 5
        @davidbrown5
        Bad fit!
        #112932
        David Brown 5
          @davidbrown5
          Just had a look on the Myford site this Quick change tool post is no longer on there but the holders are? They will be getting a call tomotrrow ! dont know
          #112934
          Chris Trice
            @christrice43267
            There are the British made ones and the cheaper ones. Make sure both the post and the holder are the British made ones. The quality between the two is not the same. A & R Precision Engineering now make the good ones and you can find them on eBay if you have to.
            #112938
            David Brown 5
              @davidbrown5
              How can i tell if they are British made, the holders do have a W stamped in the back?
              #112941
              David Clark 13
                @davidclark13
                Hi There
                Sounds like genuine Myford.
                The W is an M upside down.
                However, I don't think the
                Myford blocks were ever marked.
                regards David
                #112956
                Gordon A
                  @gordona
                  Greetings David,
                  I was always under the impression that the W was not an upside down M but stood for Weston Engineering who produced the original Myford toolposts and holders.
                  Gordon.
                  #112957
                  Kevin Bennett
                    @kevinbennett25223
                    Hi i had to machine 1.2 mm off the bottom to get the tip tool to canter
                    Kevin
                    #112959
                    David Clark 13
                      @davidclark13
                      Hi There
                      I thought Chris Moore said they got the M upside down.
                      I could have been wrong though.
                      Regards David
                      #112966
                      Kevin Bennett
                        @kevinbennett25223
                        Posted by Kevin Bennett on 24/02/2013 15:28:01:
                        Hi i had to machine 1.2 mm off the bottom to get the tip tool to centre the ones with w on them are ok the ones from RDG i had a problem with also the own Myford ??
                        Kevin
                        #112968
                        Chris Trice
                          @christrice43267
                          The cam and hole that pulls the T head into the toolpost block can wear over time. It's easy to take apart and check. I doubt very much if they're ground incorrectly. If you know someone with a good toolpost, you can easily check if the holders are at fault.
                          #113780
                          John Michael Jones (Mike)
                            @johnmichaeljonesmike
                            Quick Change Toolpost for Myford ML7.from Hemingway Kits.
                            Would apprecite drawing on experience and receive comments in respect of the design,
                            construction and usage of this QCTP: How does it compare in practice with those available
                            from RDG or HBM Tools.
                            Mike Jones
                            #113906
                            JohnF
                              @johnf59703
                              Hi David, most of my tool holders are original Myford ones made by Western Engineering [[30+years old] I also have some clones and some from A & R Precision, A & R are 100 % but he clones have all had problems of one sort or another, mainly dimensional.
                              Too thick on the base, the T slot being incorrect and another point to look at is the thickness of the flange on the height adjusting screw is sometimes too thick thus it interferes with the lockup when the cam is rotated and pushes the block away from the location ways.
                              Hope this helps.
                              David Brown 5
                                @davidbrown5
                                Sent it back to Myford and they agree it has been made wrong they think the hole that the locking cam goes into is in the wrong place. They are sending me another one out so we will see what the replacement is like?
                                #114929
                                Ian Matthews 1
                                  @ianmatthews1
                                  Hi all, if anyone is interested, A & R have just listed some QC tool post and holders On Ebay, as you know they used to make them for Myford, but can only advertise them now as UK made,
                                  UK MADE-Quick change tool post & 2 holders Dickson type,Boxford,mini lathe
                                  hope this is of interest
                                  Ian
                                  #114947
                                  joegib
                                    @joegib
                                    Thanks for the prompt. However something's gone awry with the link — this one should work:
                                    A & R Toolpost/Holders
                                    Joe
                                    #114949
                                    David Brown 5
                                      @davidbrown5
                                      A&R Toolpost ordered thanks
