Posted by Mike Henderson 1 on 12/12/2020 17:26:47:
It all depends on the ML7!!
The late ML7R is really a lite model super 7 and uses the same bed. The early ML7 that predated the first Super7 and stayed in production alongside was a very different beast and did not share the bed casting.
Whether the Super7 headstock could be physically fitted I don't know but wouldn't expect so. That said, the gap between the shears must be the same since both lathes use the same fixed steady. Can anyone do some measuring?
The parts list where I checked the numbers for the ML7 was dated 1997, but was certainly for a pre-ML7R, with the more upright headstock arrangement
According to the ML7 build spreadsheet I have, the bed casting changed in 1973, but it doesn't explain the modification.
KSL 110296 C 1973 LONG BED CASTING CHANGED
K 110296 C 1973 STANDARD BED CASTING CHANGED
K 111727 1973 APRIL 3/4 " LEADSCREW & REDESIGNED BED
Bill
