John,
IF, as you say the bed has no twist, and I think we can safely assume that your headstock in not “pointing up” nor your tailstock “pointing down” then it points to bed wear
at the headstock end. If you run your DTI along the length of the workpiece then you will notice the reading changing. For every 0.01mm the reading changes then the part Ø will change by 0.02mm so if your part is 4thou larger in Ø at the headstock end that would be round about 0.08mm which means your DTI reading would change by 0.04mm.
If you are SURE that there is no twist, then stick in a piece of steel in the chuck and turn a 60° center and use a fixed center in the tailstock. then take new measurements and see.
if you still see a difference in Ø then run the DTI along the bed and that will confirm your bed wear.
EDIT.
John,
Depending on the amount of wear the part Ø will not necessarily be double the error.
Edited By Donald Wittmann on 10/02/2012 16:19:13
Edited By Donald Wittmann on 10/02/2012 16:20:01
