Myford ML7 tools
Myford ML7 tools
Home Forums Workshop Tools and Tooling Myford ML7 tools
  • #17051
    petro1head
      @petro1head
      What size tools to buy for this post
      petro1head
        @petro1head
        I have a Myford ML7 and want to buy some more cutting tools.
        To ensure the tip is center to the chuck what size tools should I buy? I am using this tool holder:
        Also what type of tool should I buy, HSS, more carbide, indexable?
        And another poing what tools would I bneed for machining stainless steel
        Thanks
        #116524
        Brian Wood
          @brianwood45127
          Hello,
          !0mm tool shanks suit Myford size lathes, final cutting height will need to be set with shims under the tools. Your picture looks about right.
          I use brazed tip carbide and indexable carbide tools on all materials except when threading when I use an HSS tool that is easily resharpened
          You will eventually find machine and feed speeds that suit what you are doing. The usual mantra of keeping the feed heavy combined with a slow traverse ensures that the carbide tools are loaded appropriately to carve off metal in a satisfying way. Careful though with intermittent cutting when using carbide, repeated shock loads will crack and crumble the cutting edges.
          HSS prefers light cuts. It easily loses the edge by getting hot.
          I hope that helps
          #116528
          petro1head
            @petro1head
            Decisions Decisions,
            Are all indexable tools carbide
            #116701
            Brian Wood
              @brianwood45127
              No, both brazed tips and indexable tools are available in carbide and I think both have a. place in the workshop.
              #116708
              Anonymous
                Ah, so is the question 'are all inserts made from carbide', or 'are all carbide tools based on inserts'? The answer in both cases is 'no'.
                Most inserts are made from carbide, or mixes thereof, but there are other types. Two that spring to mind are:
                PCD – polycrystalline diamond for high speed machining of non-ferrous materials – up to 3000m/min; that's about 112mph surprise – I've never used them as my lathe doesn't run that fast
                CBN – cubic boron nitride used for machining hardened steel – I have used these to turn fully hardened silver steel, about 64Rc
                In both cases the inserts are eye-wateringly expensive, £25 to £50.
                #116711
                Roderick Jenkins
                  @roderickjenkins93242
                  Posted by Brian Wood on 10/04/2013 10:01:13:
                  Carbon steel loses its edge because high speed cutting causes the tool to heat up and lose its temper (if you see what mean). High Speed Steels (the clue is in the name) can usually go to red heat before they lose performance.
                  Petro1head, if you buy tools that take standard tips (CCMT is a good general shape) then you will be able to try the various grades of carbide that are available.
                  cheers,
                  Rod
