Posted by Ivy on 16/03/2021 17:12:33:
T.B
Yes, I can see that clearance for the back gear now on google images.
Unless someone has already done this I guess it will be a case of trial and error.
Hopefully someone has done it before me.
If you have a late model ML7 with a 3/4" leadscrew theres a good chance this will not even be an issue as myford started standardising parts between the ML7 and S7 , presumably to simplify production
Another thing to think about is the fixings for the rear countershaft bracket they are different between ML7 and S7's , although i'm pretty sure I have seen some beds with tapped holes to take both ML7 and Super 7 countershaft brackets
Edited By T.B on 16/03/2021 18:14:23
Edited By T.B on 16/03/2021 18:16:36
