The belt turns the pulley arrangement on the lathe headstock and the first cog in the gear, this small cog attached to the end of the pulleys turns freely around the spindle when disengaged from the bullgear or spindle(depends on system)
This small cog on the end of the pulleys drives the big backgear cog, which transmits directly along to the small backgear cog
The small backgear cog then drives the bullwheel, which is fixed to the spindle and therefore turns the spindle slowly but with huge torque
Is this a bodge by some previous owner? How do I go about seperating the Vee Cone Pulley from the spindle?
A serious bodge, your initial conclusions are correct and the pulley must be at least capable of revolving independently around the spindle
Removal… I wouldn't know about, in theory it should pop right off the spindle if the locking grubscrew is released
I would wait for any users of this old machine to reply before getting too ambitious
http://www.lathes.co.uk/myford-ml7/
Edited By Ady1 on 17/09/2012 11:56:21
