Myford ML7 Raising Block Stud Length Please
Home Forums Workshop Tools and Tooling Myford ML7 Raising Block Stud Length Please
  • #16565
    _Paul_
      @_paul_
      _Paul_
        @_paul_
        Can anyone help I finally got around to changing the bits of tatty channel currently supporting the ML7 to the proper Myford raising blocks, 1st problem was no studs with the blocks then I didn’t have any 5/16 x 22 tpi studding.
        So having made 18″ of studding and some nuts to suit  I can’t find the dimensions for them does anyone know what length the studs should be?
        Paul
        #53273
        NJH
          @njh
          Hi Paul
          If no one here can give you an answer I suggest you give Myford  a call. Despite some anti Myford sentiment from some on this forum  I find their customer service second to none. They take endless and patient care to answer any query helpfully – even some of the footlin’ things I have given them! I certainly wouldn’t swop my Myford .
          Norman
          #53296
          mick
            @mick65121
            Hi. Paul.  Tap them out to M8 its vertuialy the same pitch, you’ll only take out a smigin of swarf.   M8 studding is far easier to source, any builders merchant stocks it for fencing, then simply cut to length, thats the way I did mine, with no problems.
            #53297
            _Paul_
              @_paul_
              Hi Mick
              What length did you make them
              Paul
              #53301
              KWIL
                @kwil
                As I recall the standard length was 5″ for a metal base Myford Stand but you could get longer 7.5″ ones as well for use on a thicker bench top.
