Hi Ian,
This is how I suggest connecting the switch /motor.
1 Start winding Motor terminal R (Red wire ??)
2 Live in
3 Start winding Motor terminal S (White wire ??)
A Live in
B Run winding Motor terminal U1
C Run winding Motor terminal U2 Also neutral in.
Note live in goes to 2 terminals. Also neutral AND U2 connects to terminal C
This is on the assumption that the only continuity between the switch terminals are the ones that you originally listed plus 3 to A in forward and C to 3 in reverse.
This is how I understand the switch works.
Forward B to 2, C to 1, A to 3
Reverse B to 2, C to 3, A to 1
I think there were some errors in your original tables of connection and I cannot see on the picture of the motor terminals which colours go to U1 & U2 (I think it is blue and green but I do not know which way round.)
If you find forward and reverse are the wrong way round then swap over the wires that go to S & R or U1 & U2 (BUT NOT BOTH)
By the way when I was looking closely at the pictures of the switch to try to understand how it worked I noticed it was made by "Santon" NOT Stanton.
If you took any pictured of the disassembled switch I would be interested in seeing them.
Les.
Edited By Les Jones 1 on 27/09/2014 14:37:36
Edited By Les Jones 1 on 27/09/2014 14:38:30
