Myford ML7 Jack nut spanner problem
Home Forums Help and Assistance! (Offered or Wanted) Myford ML7 Jack nut spanner problem
  • #642468
    paul mcquaid
      @paulmcquaid48093
      Hi.
      I don't know if anyone is interested in this item. But if you want a slim spanner to fit perfectly between the Myford ML7 jacking nut, without ruining a spanner by having to grind it thinner, I found this on Amazon. Sourcing Map Thin Open End wrench, 14mm x 15mm metric £6.99 free P&P Which for less than £7 saves a lot of time trying to decide "Do I really want to grind down one my spanners? What if I find I need it someday for some heavy duty work and it needs its full thickness?"
      I don't know about anyone else on here but I go into panic mode if I can't use a tool for what it is designed for? So when I saw this I thought not only is is it ideal for my Myford setting up, But I'm sure I'll use it for other hard to access jobs too..
      paul mcquaid
        @paulmcquaid48093
        Tools
        #642469
        Jon Lawes
          @jonlawes51698
          Excuse my ignorance, which one is the jacking nut?
          #642473
          Baz
            @baz89810
            Wonder if it is the nuts on the raising block, jacking the bed up?
            #642476
            Nick Wheeler
              @nickwheeler
              Posted by paul mcquaid on 24/04/2023 18:14:39:
              Hi.
              That doesn't happen to me, I'll take the grinder to spanners, sockets etc without a second thought. And I've never met a long-term mechanic without a collection of similarly modified tools somewhere in their box. A couple of mine include a 30mm spanner cut in half and the jaws slimmed to ease the removal of Yak 18 oil lines, and the open end of an 11mm spanner with a socket welded to it making a sort-of-crows-foot to make loosening/tightening the securing nuts for the air compressor possible, let alone easy.
              #642505
              Robert Butler
                @robertbutler92161
                Sloppy & Tight on BSW/BSF fasterers!
                Robert Butler
                #642512
                not done it yet
                  @notdoneityet
                  Seven quid for a spanner that is not even the correct size?!? I would not use one of my favoured spanners, if too thick. I would get one of my old spanners (or one from a car boot sale, etc, at some point) and grind (or possibly machine) it to size. Simple, cost effective and sensible.
                  #642520
                  Martin Connelly
                    @martinconnelly55370
                    In the RAF we had two specially bent screwdrivers for the screws on the alternator connector cover. They were straight slotted screws and you could only turn them 90° at a time before swapping to the other screw driver and doing another 90°.
                    Chopping and modifying spanners/wrenches was a regular occurrence when I was at work. Heating and curving 27mm combination wrenches to fit around pipes for tightening flange nuts was a frequent request of the welders with access to oxy-acetylene. We also made curved tooling to fit on the end of spigotted torque wrenches for similar reasons. We set the torque value for these tools on a calibrated torque meter. There were quite a few half spanners welded at 90° on a long bar to reach where other tools could not go.
                    I think making and modifying tools is a standard engineering role.
                    Martin C
