Myford ML7 Clutch issues
Home Forums Workshop Tools and Tooling Myford ML7 Clutch issues
  • #20510
    David Jenner
      @davidjenner61726
      David Jenner
        @davidjenner61726
        My clutch has recently started to drag when in the dis-engaged position.
        Its the expanding drum brake type.
        I've tried adjustments and relocating the actuating arm, this did not have the desired effect.
        On inspection I've noted the following potential issues:
        The plate where the brake (clutch) shoes locate has play at the actuating cam and at its bore where it fits to the shaft, the two grub screws therefore cuase it to be off set from the true center. the actuting cam has both lateral and axial play over and above what would be requred for running clearance.
        Also I'm not sure what the minimum friction material thickness should be.
        I've also seen that the lever tilts when rotated by the pushrod.
        Which of these issues whould contribute most to the dragging?
        If I cure the dragging by adjustment there is little driving force available at the chuck!
        Is it a case of its too far gone to remedy ?
        noel shelley
          @noelshelley55608
          The ML7 and early S7 clutch was an ingenious use of a moped front brake unit made by raleigh also in Nottingham – co operation ? This matter and others on this clutch are to be found in other post to be found here. If the shoes are not true to the back plate they may well drag and the setting is quite critical ! The idea is quite basic, using the pushrod to expand the shoes but there is little room to play with ! Good luck Noel
