Posted by old mart on 04/04/2021 15:13:49:
The insert method would certainly work in theory, but absolute precision would be needed. You won't be able to just skim the front face as with a backplate. If the face does not run perfectly, […]
As before
If it was me [which it’s not, because I have two of the Myford ones] …
What I had in mind was to make and assemble the insert with the register and thread unfinished: Then clamp it to a true-running stub mandrel [no, not Neil] by its own jaws and finish to size.
A lot of faffing about, but I think it should work nicely.
Alternatively … the chuck may look like Nick’s one from the other thread [von dutch hasn’t commented on that] in which case the preferred solution might be different.
