Myford ML7 4 way tool post
Home Forums Workshop Tools and Tooling Myford ML7 4 way tool post
  • #136367
    Patch Wheatley
      @patchwheatley65096
      I want to make a 4 way tool post for a Myford ML7 and need dimensions.
      Can anybody help?
      hope so
      regards
      Patch
      Patch Wheatley
        @patchwheatley65096
        ML7 4 way tool post – dimensions needed
        #136488
        Robbo
          @robbo
          Hi Patch,
          In Len Sparey's "The Amateurs Lathe" there is a design for a simple 4-way, without indexing and built up from 3 pieces to avoid milling a slot in a "chunk"
          See below – hope this helps
          #136508
          North Western
            @northwestern
            Hi Patch
            Full details of an excellent 4 way indexable tool post are in George Thomas “Model engineers workshop manual”, I believe he gives details for both the ML7 and S7, though I am unable to check my copy. Perhaps someone else can confirm this.
            I modified his design and built several of these tool posts to fit non-Myford lathes, including a simplified non-indexing version, and as with all his designs, with careful work you end up with a quality product.
            John Olsen
              @johnolsen79199
              What about a Lammas three way tool post? The machining might be a little bit harder because it is not square, but they are very convenient and you don't knock yourself on the other tools so often. (Three tools is usually enough.)
