Myford M – a few random questions
Home Forums Workshop Tools and Tooling Myford M – a few random questions
Viewing 6 posts - 26 through 31 (of 31 total)
  • #604178
    Hopper
      @hopper
      Posted by Jon Lawes on 04/07/2022 07:29:58:
      Posted by Hopper on 03/07/2022 23:55:28:
      Posted by SillyOldDuffer on 03/07/2022 13:34:26:
      I prefer inserts to HSS for exactly the reasons Alec gives: they potentially eliminate the need to buy a grinder and learn how to use it. Not everyone is good at grinding, so beware folk to whom it came naturally: they insist it's easy and just needs a bit of practice. Yeah right, so does learning Integral Calculus…
      When I was in high-school, every 15-year-old boy could grind a lathe tool bit, sharpen a drill bit and a plane blade. Was part of the metalwork/woodwork class that all boys took. I don't remember any boy who could not master all three skills in fairly short time.
      It;s not rocket science, or even integral calculus.
      Edited By Hopper on 04/07/2022 00:06:09
      I can sharpen HSS, but find carbide suits most things I need to do. As mentioned, it's useful for unusual shapes or form tools, but for the most part my pile of HSS cutting tools is gathering dust.
      I'm sure most people could operate a treadle lathe rather than an electric motor, but who wants to do that if there is a better option?
      But that doesn't mean you should throw the baby out with the bathwater and not have a bench grinder at all, throwing away drill bits as soon as they get dull and leaving yourself unable to make up special purpose lathe tools such as form tools or others as needed from time to time. And if you really want to get the best off-tool surface finish and sub-one-thou accuracy on a small lathe, good HSS tooling is superior to even the ground inserts.
      (BTW I am with you in that I can grind HSS tools but these days use carbide for 75 per cent of work.)
      Edited By Hopper on 04/07/2022 08:02:09
      Jon Lawes
        @jonlawes51698
        I agree.
        #605065
        Alec Gunner
          @alecgunner39277
          Thank you for the further comments on tool design/selection. The thread has wandered (as they do) but for me it's all useful information as I set myself up to use the lathe rather than just fix it.
          The C spanner has arrived, the spindle has been removed and the bearing realigned. A bit of head scratching as to how to turn it but a drawing courtesy of David George indicated that the bearings are externally conical so re-fitting the locking ring and tapping the bearing back using a wood block had it loose so I could rotate it. Fortunately the wedge is still present.
          I also realised that the wedges have to be inserted from the inside, and that removing the spindle alone does not allow the pulley cone to be removed from the headstock as it won't clear the casting without also removing the back gear. Fortunately everything is clean and smooth, and none of the thrust bearing balls dropped out, so I decided to leave that alone and simply reinsert the spindle.
          I have also dressed out the worst of the abuse on the locking ring slots – mostly it was possible to 'forge' it back into place. They are still a bit ugly but much better than they were.
          I will make up a temporary oiler bolt today and get it set up and running. Assuming everything goes well I can then look to make some proper drip oiler bolts and the other short-term need to is to machine a register on a faceplate which I have picked up that has the correct thread but no register, and then probably purchase a backplate for a 4-jaw chuck (having now bought a suitable Burnerd chuck) and do the same.
          I might eventually manage to use the lathe to make things other than for the lathe itself – otherwise this could become a self-sustaining project in its own right!
          Alec
          #605066
          Hopper
            @hopper
            Ah yes, making tools to make tools to make tools is a well known hobby! Enjoy.
            #605088
            Ady1
              @ady1
              This is where mobile phones finally come in useful
              If you strip down an unfamiliar bit of kit video the process with a phone and reassembly becomes a doddle
              #605179
              Howard Lewis
                @howardlewis46836
                As Hopper says, you are on the slippery slope already!
                But it all good practice and experience., which will, as we say "Come in handy, one day"
