Posted by Roderick Jenkins on 01/02/2019 10:41:51:
Chaps,
I accept the collective wisdom of the desirability of cutting the teeth in one pass but can somebody please explain to me the mechanism of more than one pass blunting the cutter?
If the tool is applied to cut in one pass, the whole cutting edge is applied to the work once only. Conversely, when the tool is applied in steps, the wear concentrates on the sharp end of the cutter. It's because, when nibbling, the sharp end does most of the work and goes blunt while the other end of the tool's edge is barely used at all.
Provided the machine has enough grunt and the tool can take the strain, using the maximum amount of edge possible per cut will extend the life of the tool. This is important in industry, but even something the size of Bridgeport has limits, which is why hefty horizontal mills are popular.
In practice, because my hobby mill flexes and the motor complains when pushed hard, I usually take more passes to remove metal than is ideal. Compared with the risk of damaging the machine or getting a poor finish the extra wear on the end of the cutters doesn't worry me much.
Rubbing tools with very light cuts is to be avoided at all costs. As well as concentrating the wear, rubbing rather than cutting damages the edge rather quickly. Being over gentle with cutting tools is a good way of reducing their useful lives.
