Myford
Myford
  • #210548
    kevin large
      @kevinlarge76611
      Hi I've just acquired a myford ml7 tri lever just got it set up and noticed the thread dial indicator turns when the lead screw is turning but when I engage the half nut it stops is this how it should be I've not ryed screw cutting yet but looks quite complicated to set up any tips on this would be good
      Thanks in advance
      kevin large
        @kevinlarge76611
        Thread file indicator
        #210549
        NJH
          @njh
          Relax Kevin
          That's how it is supposed to work! The indicator rotates and tells you when to engage the clasp nut.
          I' m away from the workshop & my data at the moment but will post tomorrow if no body can give you the detailed info. in the meantime.
          Norman
          Edited By NJH on 03/11/2015 22:52:58
          #210561
          DMB
            @dmb
            Hi Kevin,
            I have an MLS-7 with a threading indicator. I have slacked-off the clamp nut and swivelled it round a bit so gear @ bottom of fitting doesn`t engage leadscrew under normal useage, i.e., when not screwcutting. The idea is that if thread being cut is a multiple of leadscrew thread, in this case, 8tpi, then you can re-engage the clasp nut @ any of the 4 divs, This only applies to Imperial not Metric threads. HTH.
            John.
            #210562
            Lambton
              @lambton
              Kevin,
              Please get yourself an official Myford handbook for your lathe as they are very informative and tell you almost all you need to know. You can download a pdf from the net or buy one from new Myford.
              Also useful is "Myford series 7 manual" by Ian Bradley which is currently in publication.
              #210574
              Martin Kyte
                @martinkyte99762
                Why would you wish to dis-engage the screw thread indicator DMB ?
                Martin
                #210590
                NJH
                  @njh
                  Hi Kevin
                  I suggest that you sign up with Yahoo groups where there is a group devoted to Myford lathes. The group is HERE
                  You will find the info. that you seek but I endorse "Lambton's" advice that you buy the Bradley's Myford Series 7 Manual – lots of useful and relevant information ( Loads of copies available from Amazon from about £4)
                  Norman
                  #210597
                  old Al
                    @oldal
                    Martin
                    You disengage the screw thread indicator to save wear. The same reason to disengage the gearbox when not in use.
                    Screwcutting can be very frustrating and great fun. But i would suggest getting someone to show you how its done first. reading books make it look so difficult.
                    #210598
                    Muzzer
                      @muzzer
                      Check out a few Youtube videos. Almost as good as finding someone to show you.
                      #210601
                      Ian S C
                        @iansc
                        Check out Youtube Vidios, or be like me, just get stuck in and do it, and it worked, the tool I used was a bit off an old square file( I think it's still in the lathe tool draw). I chose a large thread for a first, 3/4" BSW,(10tpi), a smaller, fine thread is easier.
                        Ian S C
                        Edited By Ian S C on 04/11/2015 11:22:37
                        #210603
                        Martin Kyte
                          @martinkyte99762
                          I cannot see that the wear caused by what is effectively a rack and pinion driving a freely moving indicator spindle is going to be significant. I can fully understand disengaging the gearbox as the loading is many times more significant. In fact if you stick the tumbler gears in neutral the leadscrew doesn't turn and the thread indicator only moves when you track the saddle. Any significant wear is going to come from the saddle handwheel pinion gear. So that why I leave the dial indicator permanently engaged.
                          Martin
                          #210605
                          kevin large
                            @kevinlarge76611
                            Thanks for the replies I have the myford manual but not sure which is the idle gear is metric 1.5 21 50 45 35idle 40
                            #210651
                            Lambton
                              @lambton
                              If anyone must keep their thread dial indicator permanently engaged then ensure it's spindle is lubricated from time to time using the small oiler in the centre of the dial. Better to disengage it when not in use as it serves no purpose to keep it engaged when not screw cutting.
                              #210662
                              Mike Poole
                                @mikepoole82104
                                The thread indicator is usually mounted with fibre washers and adjusted to be a firm push to engage or disengage as required.
                                #210674
                                John Haine
                                  @johnhaine32865
                                  Kevin, I don't understand what you're asking in your last post, please could you clarify? Myford "metric" lathes are identical to the imperial ones except that the cross and top slide feed screws are 2 mm pitch. The leadscrew remains 8 tpi.
                                  #210685
                                  kevin large
                                    @kevinlarge76611
                                    Sorry it’s an imperial lathe but I want to set to cut metric 1.5 pitch thread but looking at the book it doesn’t state which is the idler gear
                                    #210687
                                    Roderick Jenkins
                                      @roderickjenkins93242
                                      Kevin,
                                      Perhaps it's more explicit in my S7 manual:
                                      21 driver
                                      50 driven paired with 45 driver on 1st stud
                                      35 as idler on 2nd stud
                                      40 driven on lead screw
                                      HTH
                                      Rod
                                      #210696
                                      DMB
                                        @dmb
                                        Martin,
                                        If you read various posts above, people like Lambton have answered your question.
