Posted by Chris Trice on 19/09/2012 11:44:57:
Problem with that Andy is that bought ones are generally hardened and ground. to get plus the option to correct for manufacturing faults in the taper section. It's quick and you only have to do it once.
My other ER25 chuck, which incorporates a flange to match the flanged spindle of a Chinese lathe, needed its taper skimming true, Chris. I had no problem doing that on the lathe with an HSS tool.
The Myford-style one on my miller doesn't seem to be hardened, either, if the scratch I've just put on its outer rim with an old drill bit is any guide. But they may vary between manufacturers or batches.
Andy
