My week this week! My workshop videos
Home Forums The Tea Room My week this week! My workshop videos
Viewing 25 posts - 251 through 275 (of 287 total)
  • #730135
    Phil Whitley
      @philwhitley94135
      Hi folks,
      This week I get the heat exchanger up on the ceiling, get the boiler in position and finsh most of the plumbing. On Friday I visit a retired precision engineer of very wide experience to put some more three phase sockets in his workshop, and have a good look around at his collection of machinery and one of the many innovative things he has built! A very interesting week!
      Sunny and warm in East Yorkshire? It won’t last!!
      Phil
      Phil Whitley
        @philwhitley94135
        Hi folks, a mixed week of triumphs and tragedies, but I soldoer on through to the end, and actually achieve a lot, the good news is the plumbing is finished! For the bad news see the end of the video!!
        Phil in warm and only occasionally wet East Yorkshire!
        #732393
        Phil Whitley
          @philwhitley94135
          Hi folks,
          This week I finish the new grinder bench and then start the job I am not looking forward to! Seeing if I can repair the leak in the hunter stove. So its out with the plasma cutter, off with its bottom, and dive in! All in all a succesful week!
          Phil in wet and COLD again East Yorkshire
          #733680
          Phil Whitley
            @philwhitley94135
            Hi folks,
            I get the boiler back together, reinstalled, but just get started on the flue and run out of Mig gas, so its on to some other joblets to fill in! Boiler is refilled with no leaks, so the Fernox leak sealer has triumphed once again, other makes are available! A short, mainly wet week!
            Phil, June 1st is grey and cold in East Yorkshire!
            #734876
            Phil Whitley
              @philwhitley94135
              Hi folks,
              A very short week of modifying an inherited partly made(?) stand to suit my very heavy gas forge, so thatI can use it anywhere in the shop, as opposed to having to carry it to some level surface and set it up to use! Only got a couple of days in before life overtook me, but much was achieved!
              Phil, in occasionally warm and sunny East Yorkshire!
              #736264
              Phil Whitley
                @philwhitley94135
                Hi folks,
                I get the gas forge up on its stand, change the gas burner orientation to make it more compact, and get it running in order to heat and flat bend some strip steel. Then I get the new boiler flue fitted and fit a new thermostat so it will self regulate and shut down if it gets too hot! Looking at the weather I might need it! Time to test it soon!!
                Phil, splish splashing through the EastYorkshire monsoon!
                #739825
                Phil Whitley
                  @philwhitley94135
                  Hi folks,
                  I get to the root of my heating problem when I strip the pump down, but only manage one and a bit days at the workshop this week! The bushings on the pump are very worn and the rotor is catching on the stator and the pump locks up. I have an ominous feeling in the back of my mind that thisis why I took this pump out of service in the first place! We find that no matter how many of a thing you have in your pile of junk, you eventually use up the last one!
                  Phil, deep in the steamy rain forest of East Yorkshire!
                  #741206
                  Phil Whitley
                    @philwhitley94135
                    Hi folks,
                    A mixed bag this week! I fix the garden tractor after it takes on a tree stump and loses, get started on realigning the colchester lathe (more next week) Do the inevitable tidying up, and have two very productive days of antique repairs ! Enjoy!
                    Phil, the central heating is on in East Yorkshire!
                    #742343
                    Phil Whitley
                      @philwhitley94135
                      Hi folks,
                      Part two of aligning the Colchester headstock, plus stripping and rebuilding a three jaw chuck, in order to clean and oil it, and get it working to its full potential accuracy and smoothnes! Three jaw chucks all have runout, even when brand new and good quality, expect 3 to 4 thou runout, and more on an import! They are convenient and quick, and as long as you are turning all the diameters of your component, any runout is ireelevant, but if you need to use the outside diameter of the bar as well, it will not be concentric with the diameters you have turned! If you need to do this, use a 4 jaw! A 4 jaw is the most accurate chuck you have!
                      Phil, in sunny hot and summery East Yorkshire! It won’t last!!
                      #743892
                      Phil Whitley
                        @philwhitley94135
                        Hi folks,
                        This week I strip the Holbrook countershaft and work out the sliding positions for the upper pulley to obtain the 12 speeds on the Holbrook, six selected by belt changing, and the back gear giving another six. I pop over to my mate Richards in the derwent valley and we troubleshoot his Ingersol rand “$” compressor We get it running in short order but there is a fault on the unloader system which turns out to be the non return valve has failed. And then the what is it! Something interesting from a York car boot, prably with a military history, have a look and let me know in the comments, and dont forget to subscribe!!
                        Phil, in pleasantly warm and sunny East Yorkshire!
                        #744981
                        Phil Whitley
                          @philwhitley94135
                          Hi folks,
                          A mixed week in which I get some more work on the Holbrook in, and realise that my envisioned solution for the countershaft arrangment is fatally flawed, and with thanks to the Guru of all things Holbrook, Mr John Bourke, I rethink it all and take his sage advice to heart!
                          After an early morning at York Uiversity on Tuesday for My eldest to get her Masters in Biology Graduation, we go on to Wednesday grass cutting in the field, back on the Holbrook Thursday, and Friday, in sweltering heat we start the fence that we started on the day lockdown was imposed at the start of Covid!
                          Phil, summer has arrived in East Yorkshire
                          #746281
                          Phil Whitley
                            @philwhitley94135
                            Hi folks,
                            This week we complete the final preparations for the annual Wicani Jamboree, which is a get together of dog breeders and owners held annually on the field owned by my cousin Keith and I. This involves doing all the maintenance, repairs and tidying up we should have done at regular intervals during the year, and doing it all in about two weeks to make the place look great and to try (and usually fail) to impose some order on the chaos of nature! There is no such thing as natural beauty in nature! Eventually the strongest weeds take over and you are left with a monoculture of nettles, blind brambles and thistles. Sometimes we win, but mostly it just a wilderness! We love it, but really could live without the work it takes!
                            Hope you enjoy it,
                            Back on the Holbrook next week!
                            Phil, in pleasantly warm East Yorkshire.
                            #747507
                            Phil Whitley
                              @philwhitley94135
                              Hi folks,
                              A whole uninterrupted week in the workshop! I get the majority of the build done, designing it in my head as I progress! The worst part was derusting the steel, the best was the welding AFTER I fitted a new contact tip! Also advanced two tech levels with the Rapidor, got the damper working correctly to lift the saw on the backstroke, and got the vice to cut at 45 degrees! Did an unscheduled angle grinder fix, but after all it did come out of a skip several years ago! Good progress!
                              Phil warm and dry in East Yorkshire
                              #748701
                              Phil Whitley
                                @philwhitley94135
                                Hi folks,
                                Another week in the workshop, not quite uninteruppted, but I virtually finished the belt tensioning mechanism, and fit in a couple of side jobs as well, a quick repair on a part for an astronomical telescope, and watch to the end to see a quick tidy up of the workshop!
                                Phil, in Wild and Windy East Yorkshire
                                #750399
                                Phil Whitley
                                  @philwhitley94135
                                  Hi folks,
                                  Another short week due to hospital appointments and daughters returning to university with a pantechnicon load of stuff! We did it! Phase two, the motor mounting, clutch and brake assembly is begining to take shape in the noggin, and I am ready to mount the motor, I finally after much procrastination, fit the starter to the Rapidor, which is now fully automated and I can walk away from it and let it cut and autostop! How 20th century is that!!
                                  Phil in Scorchio East Yorkshire!
                                  #751781
                                  Phil Whitley
                                    @philwhitley94135
                                    Hi folks,
                                    On the Holbrook, I set up a double pulley on the motor to give two speeds from the motor, which restores all of the Holbrooks 12 speeds, I get the motor mounting plate sorted, and set up a sliding system in order to select the two pulley positions, and basically, it is all falling into place. A visit to Haxby shed to meet Paul on his home ground, some biographical notes, and a look round his very clean and tidy workshop, which is filled with some classic machine tools!
                                    Phil, in Autumnal East Yorkshire
                                    #753525
                                    Phil Whitley
                                      @philwhitley94135
                                      Hi folks,
                                      On with the Holbrook B9! I get the motor mounted and start to work on a mechanism to disconnect the drive without turning the motor off. What seemed to be a simple case of a slipping belt clutch, which I have used before many times, including on the 2CV tractor, doesnt work well in this application with much shorter belts and tighter wrap around the pulleys. I learn about the fabric covered V belt which is designed to slip with anything but a full wrap and consider the possibility.  It is coming together, and after reversing cleaning and servicing the motor, she runs, and in the right direction too!
                                      Phil Its beginning to be chilly in East Yorkshire
                                      #754873
                                      Phil Whitley
                                        @philwhitley94135
                                        Hi folks,
                                        This week the pulley slipping clutch starts to work, thanks to some input from Gardentractorboy! I fit two belt guides and hey presto, the belt slip clutch works! I get a pivot made and fit a square “cam” to the end, and we have a system that moves the motor from drive to free in one movement! I struggle on through various interruptions, some more welcome than others, but end the week on a positive note with a drive system clutch that works a treat!
                                        Phil, geting a bit “back endish” in East Yorkshire
                                        #756341
                                        Phil Whitley
                                          @philwhitley94135
                                          Hi folks,
                                          All the Holbrook transmission comes together this week, and it all works, and then a huge penny drops, and with one change, my cunning plan bears fruit! I explain it all in the video! I am still getting over 60% of my viewers are not subscribers, please subscribe! Its free and it helps me move towards the time when I might actually get some of the time and money I put into my projects back!
                                          Next week will be finishing off, and a belt guard, plus eliminating any buzzes and rattles which crop up! Warning, contains gratuitous Rapidor porn!!
                                          Phil, in very wet East Yorkshire!
                                          #757537
                                          Phil Whitley
                                            @philwhitley94135
                                            Hi folks,
                                            eThis week starts with a sidetrack, a sure sign I need a break from the Holbrook project to get the creativity flowing again! I took one look at the cold damp weather and realised I would soon need to heat the workshop, and so decided to get to the bottom of the circulation problem and did just that, but what a game it was, and I am still not sure of the cause, though it was definitely a blockage, physical or air, that was the cause! It is now fixed, and the pump is silent, and actually circulating the water!Typically, the next day and the rest of the week were bright and very warm! On with the Holbrook, I fit the control handle stop, and start making the belt guard, the final step before it all comes to pieces for painting!
                                            Phil, in wet and cold then dry and warm East Yorkshire
                                            #758965
                                            Phil Whitley
                                              @philwhitley94135
                                              Hi folks,
                                              This week I make the belt guard for the Holbrook lathe, and make and fit the stop and the hold up mechanism. Some TIG and Mig welding, a bit of milling, but no Rapidor this week! Thursday/froday my old mate Richard Teale comes over, and we fit a new roof to the blacksmiths shop area of the workshop. This morning I am stiff as a board and ache all over, but it is done apart from the last 1/2 sheet as you will see!
                                              Phil, in typical East Yorkshire weather! It can’t make its mind up!!
                                              #769284
                                              Jim Young 2
                                                @jimyoung2
                                                Anyone know if Phil is OK?
                                                #778278
                                                Phil Whitley
                                                  @philwhitley94135
                                                  Hi folks,
                                                  Back in the Workshop for my first attempt at a full week, although in reality I am doing 11-00 till 4-00! It is enough at the moment as believe it or not I average about 3.5 miles a day! Tiring but I did it! It will get easier! A day of fallen tree clearing on Tuesday and the rest on the belt guard for the Holbrook lathe. I hoped to complete it, but will do that early next week!
                                                  Thanks for watching!
                                                  Phil, in Chilly East Yorkshire.
                                                  #778385
                                                  Phil Whitley
                                                    @philwhitley94135
                                                    Shot this just before Christmas, put it on the tube, but forgot the forums! obviously not quite firing on four at the time!
                                                    Phil
                                                    Hi folks, Just a short video to show I am still alive and kicking up a fuss! A few odd jobs to clear the decks before the festivities begin! Thank you all for your patience, and I hope you all have a wonderfull Yule and a bright and happy new year!
                                                    Bright blessings to all! Phil
                                                    #779928
                                                    Phil Whitley
                                                      @philwhitley94135
                                                      Hi folks,
                                                      I get the belt guard finished, and a few other little jobs completed on the Holbrook B9 and the realisation dawns that it is nearly finished! I have the collet draw tube to complete, and the belt guard pivot to finalise, and then it is time to finalise the underframe, and remove it to drill the holes for fixing and lifting, aqnd then it’s paint, paint and more paint!
                                                      Phil, in Wild wet and windy East Yorkshire
