My next lathe
My next lathe
Home Forums Workshop Tools and Tooling My next lathe
Viewing 15 posts - 1 through 15 (of 15 total)
  • #103974
    chris j
      @chrisj
      I'm thinking of getting another Lathe, I have a Myford Super 7 with a power cross slide, it's a nice machine, but I fancy a change.
      I have a thread running about a couple of Warco lathes, but wondered what else you guys might suggest?
      So lets say I have around £3k in the pot.
      I'd like something a bit larger than the S7 but not necessarily massive.
      A must have would be a 2 axis DRO
      A decent spindle bore. Power feeds. Metric.
      Coolant system & maybe a one push oiling system.
      I think I'd prefer a 3 phase machine & inverter, but it's not a deal breaker.
      Any thoughts guys and gals. (No prize for the first person to say don't change).
      chris j
        @chrisj
        #103977
        Bazyle
          @bazyle
          Are you intent on new? Do you actually need a large turning diameter? How about considering a solid old toolroom lathe which would make a nice contrast to the lightweight myford.
          #103978
          _Paul_
            @_paul_
            Personally to get the most bang for your buck I would go used, £3k could buy a very decent used Colchester or Harrison, is machine parking space an issue?
            Paul
            #103979
            chris j
              @chrisj
              Posted by Bazyle on 17/11/2012 14:03:11:
              Not set on a new lathe, I have looked at a Harrison M300, but the good ones are a bit expensive when I want to add a DRO as most don't seem to have them fitted.
              #103980
              chris j
                @chrisj
                Posted by _Paul_ on 17/11/2012 14:43:12:
                Paul
                No not really, I have a decent amount of room.
                #103991
                KWIL
                  @kwil
                  For £3K you will get a half decent M300, but you probably will have to add your own DRO. If you look in my Photos you will see my M300 (from the rear) with the back DRO scale in place. Photo alongside is a miniature mounting block (own design) which uses existing M3 holes on the rear face of the bed.
                  #103995
                  Ady1
                    @ady1
                    Colchester or Harrison or Boxford IMO
                    Whatever you do, don't buy in haste
                    #103999
                    NJH
                      @njh
                      Or why not go on a diet ( or some other money saving scheme) for a while then splash out ……………….?
                      I wish !!!
                      Edited By NJH on 17/11/2012 17:31:27
                      #104000
                      Ex contributor
                        @mgnbuk
                        Ebay 271102861912
                        One of 4 ex- training establishment Warco 1322 machines with all original equipment for sale by same seller – asking £1900 each. Plus a 1330 in another listing for £2400 – all around £1000 under Warco list.
                        Finding a "nice" (as in "not clapped out, ex-industrial&quot Harrison or Colchester will not be easy. A gear head Boxford would a good bet, if you could find one. Or if you want a well specified, solidly built machine & don't suffer from badge snobbery, a smaller Czech built TOS or Russian lathe.
                        Nigel B.
                        #104001
                        chris j
                          @chrisj
                          I have spotted those Nigel but thanks for the tip.
                          I also have my eye on an M300
                          I think the advice not to rush is probably good advice.
                          Thanks Guys & Gals keep it coming.
                          Chris
                          #104002
                            Chris bear in mind that not all M300s have a gap bed which may restrict you on a traction engine as you won't fit a flywheel and final drive off a 3" engine on it
                            J
                            #104003
                            chris j
                              @chrisj
                              Posted by JasonB on 17/11/2012 18:24:48:
                              J
                              Good your on the case J – Thanks
                              #104004
                              chris j
                                @chrisj
                                Posted by Nigel Barraclough on 17/11/2012 17:54:38:
                                Ebay 271102861912
                                Finding a "nice" (as in "not clapped out, ex-industrial" Harrison or Colchester will not be easy. A gear head Boxford would a good bet, if you could find one. Or if you want a well specified, solidly built machine & don't suffer from badge snobbery, a smaller Czech built TOS or Russian lathe.
                                Nigel B.
                                I don't have a problem with Russian or Far Eastern equipment as long as they have a decent spec and reputation. I think the days of Britain being the leaders in Engineering are long gone tbh.
                                #104022
                                mickypee
                                  @mickypee
                                  Harrison M300, you will never look back.
