Posted by Ron Laden on 31/01/2021 13:45:23:
Just thought it best to check with you guys so I dont make an error, will a carbide insert (ferrous type) manage to cut the jaws of a 3 jaw chuck ok..? I know the jaws are hardened but wondered how much.
Edited By Ron Laden on 31/01/2021 13:47:34
See if the jaw can be scratched by a file first. Whilst Carbide is harder than the hardest steel, a very hard steel will give carbide a run for it's money. If the jaws scratch, they're relatively soft and carbide has a good chance. If the file bounces off, then carbide will struggle more. Carbide will win the fight but it could be painful.
Grinding is better for hard materials.
Re jaws, the limit is set by the number of teeth engaged in the scroll, and how brave you are!
The 3-jaw on my HV5 will just hold 65mm diameter but 3 of the teeth are completely outside the chuck:
![dsc06393.jpg dsc06393.jpg](data:image/gif;base64,R0lGODlhAQABAAAAACH5BAEKAAEALAAAAAABAAEAAAICTAEAOw==)
Looking inside the slot, it can be seen only one tooth is engaged with the scroll, and at full extension it's marginal: any further and the jaw disengages.
![dsc06394.jpg dsc06394.jpg](data:image/gif;base64,R0lGODlhAQABAAAAACH5BAEKAAEALAAAAAABAAEAAAICTAEAOw==)
I would trust this chuck up to about 50mm diameter, and might risk holding a light job up to about 60mm. Depends on the design, other chucks might be a little better or a little worse. Since a big job levered itself out of a chuck with a metal bending bang I've been less brave! The further the jaws come out, the more nervous I get, but it's a judgement call.
Edited By SillyOldDuffer on 31/01/2021 14:25:28
