My first foray into clock repair
Home Forums Clocks and Scientific Instruments My first foray into clock repair
Viewing 6 posts - 51 through 56 (of 56 total)
  • #341029
    Bodger Brian
      @bodgerbrian
      Thanks for all of the comments, gents. I know some of them contradict others but all are welcome.
      I made the decision to try adjusting the crutch on it’s arbour. Bad move! All that achieved was that the pendulum still hung at the same angle & the pallets were now totally out of position with the teeth of the escape wheel. I managed to get it back where it was (I think), then applied a bit of tweaking to the crutch (as shown in the drawing posted by Fowler’s Fury).
      This resulted in a case of one step forward, one step back. The pendulum now hung vertically (or as close as I think I’ll get it) but the clock refused to run. I then slackened off the two screw on the bracket holding the suspension spring & adjusted it’s position (and hence the relationship between pallets & escape wheel). Admittedly by more luck than judgement, after a lot of blood, sweat & naughty words, I managed to get it to run. Here come the next questions :-
      1) When I managed to get it to run, it only did so for a short period, one or two hours at the most, no matter how often I set it running. I’ve now come back to it after a few days, set it running again & it’s been running for over 10 hours. Why would it not run successfully now but not earlier, with no adjustments being done in between?
      2) I found it very difficult to make small adjustments to the bracket. Not slackening the screws enough meant that the bracket couldn’t be moved, whilst slackening them too much meant that the bracket would drop under it’s own weight & I’d have to start again. Any hints or tips in this respect?
      Edited By Bodger Brian on 11/02/2018 20:07:31
      Redsetter
        @redsetter
        This may sound patronising – if so I apologise. I doubt whether there was anything wrong with the depth of the escapement as I said in a previous posting, as the clock would run without the pendulum. Anyway you seem to have got that about right.
        The slots in the back cock (the bracket in question) are vertical so all that moving the bracket does is move the pallet arbor vertically. It has nothing to do with the beat adjustment, or the way the pendulum hangs. To answer question 2. it is difficult to adjust because it is a clock! I have the impression you were trying to adjust it with the pendulum in place – don't. Take the pendulum off and lay the movement on its front – supported for example on top of an open box.
        If he clock is stopping consistently after say, one hour, then there is something in the movement which is jamming every hour, so it must be on a part which rotates once an hour. It is worth taking off the hands and motion work (the reduction gears which drive the hour hand) and see if it then runs continuously, as this is a possible cause of jamming.
        I think though that if you haven't cleaned the clock yet you should do so as it could well be stopping just because it is dirty. I would bath it in white spirit rather than petrol, as modern petrol ends to leave a deposit on the plates.
        #341037
        Bodger Brian
          @bodgerbrian
          Redsetter – not patronising at all. Apologies if the following comes across the same way.
          To summarise :- I had removed the hands & dial & cleaned the pivots (without dismantling the movement), then re-oiled. The clock had previously been running continuously but with the pendulum offset / not hanging vertically. All of my latest travails had been an effort to rectify that. It was also pointed out by a previous poster that one of my photographs showed the movement stopped with a pallet on top of one of the escape wheel instead of in front of it, which should be rectified – hence my adjustment of the back-cock.
          I had found that adjustment is difficult – hence my asking if anybody had any hints or tips on how to make small adjustments.
          Edited By Bodger Brian on 11/02/2018 21:34:06
          #341379
          Fowlers Fury
            @fowlersfury
            Brian ~ my last posting suggested that any advice of mine should be ignored, given all that provided by the experts above. Yet your request … "hence my asking if anybody had any hints or tips on how to make small adjustments." remains unanswered.
            You might find it interesting to read "Is there a standard for adjusting palette height on escape wheel?"
            Over and out.
            #341386
            julian atkins
              @julianatkins58923
              Hi Brian,
              Listen to the noise the clock makes when set up. I know this sounds elementary but a trained ear will be able to tell when the escapement is correct simply by listening to lots of other well set up clocks.
              Cheers,
              Julian
              #360378
              Bodger Brian
                @bodgerbrian
                Just to bring this thread to a natural end, I'd just like to say many thanks to those who have taken the time to patiently answer my perhaps naïve questions – it's been much appreciated.
                After many a long hour of tweaking, I've managed to get an even beat and although the pendulum still doesn't hang quite correctly, it's a big improvement on what it was. I've decided that I need to accept that at this moment in time because of my inexperience I'm not going to improve matters, so the clock is now hanging in our hallway. All that remains is to adjust the pendulum bob – it's currently losing about 1 minute over a couple of days.
                I now have a non-running mantle clock in my possession, which I intend to strip down and get back into running order. I feel a new thread coming on…..
