M&W Telescopic Bore Gauge
Home Forums Workshop Tools and Tooling M&W Telescopic Bore Gauge
  • #612404
    COLIN MARTIN 2
      @colinmartin2
      Hi all,
      I have a M&W Telescopic Bore gauge, 12.7 -19mm, and I have lost the spring out of it (don't ask) incredibly, M&W do not supply spares! A tool that they produce, but cannot supply a spare for seems mad to me, but has anyone any ideas where I may get one?
      Thanks,
      Colin
      COLIN MARTIN 2
        @colinmartin2
        #612406
        Baz
          @baz89810
          Obvious place is a spring manufacturers catalogue, try googling spring manufacturers, or buy some spring wire and wind your own.
          #612408
          COLIN MARTIN 2
            @colinmartin2
            Thanks, it is a tiny, long, powerful spring and I doubt I'll find one.
            #612415
            Anonymous
              Flexo Springs stock a wide range that can be ordered online:
              Flexo Springs
              #612416
              Neil Lickfold
                @neillickfold44316
                If you can think of the wire gauge size, then you can make one by wrapping the spring wire/Piano wire , around a drill bit shank and make your own spring. If you have the next size up gauge, take it apart to see what the gauge and diameter of that spring is. You will find that they are not really that difficult to make once you get the hang of making springs.
                Edited By Neil Lickfold on 05/09/2022 10:15:00
                #612458
                old mart
                  @oldmart
                  I have bought springs on ebay, there is an astounding range for sale.
                  #612488
                  Howard Lewis
                    @howardlewis46836
                    If they are still trading, you could try Vincent Springs in Peterborough, UK.
                    Just checked their website, and they are actually in Ramsey
                    Tell them what you want, and they will probably make one for you
                    (The other gauges probably use the same spring, so you should be able to measure:
                    Free length, Wire diameter and Number of coils, which should help to get a suitable spring. )
                    #612541
                    COLIN MARTIN 2
                      @colinmartin2
                      Thank you all for the feedback, I will investigate!
                      Cheers,
                      Colin
                      #612542
                      Brian G
                        @briang
                        Heresy perhaps, but it might be cheaper to buy a cheap Chinese set and try out the spring from that. If it doesn't fit you could sell it on or have a second-best set.
                        Brian G
                        #612589
                        COLIN MARTIN 2
                          @colinmartin2
                          Thank you to all those who helped with suggestions. Unbelievable as it sounds, I have found the spring! It was on the other side of the garage laying on the floor, and it is something of a miracle to have found it.
                          Cheers everyone,
                          Colin
