Malcom
You set the cross slide or, better taper turning attachment, angle by reference to the internal headstock taper using a lever type indicator running on the back side of the headstock taper. Why back side? Because the turning direction will be small end to large which is the stiffest way.
If I absolutely had to do a foreign taper I'd use the two collar method. Bad enough with a taper turning attachment and a royal pain with a top slide but its as accurate as your patience makes it. Work out the collar diameters using the gauge length along with the small and large end diameters from the specifications. Never use angles as folk like us aren't set up to make sufficiently accurate measurements. Slopes are far easier to get right. There are darn good reasons why inches per foot et al was the way things used to be done.
With only common Model Engineer – Home Workshop Guy (or Gal) it's not possible to reliably and quickly set up the angle to book values with sufficient accuracy and within tolerance. Improvised / knife'n fork methods can sometimes work but all too often end in disaster or, at best, a marginally acceptable fit. Whatever the write up, internet reference or YouTube video may say or imply.
Turning an accurate morse taper is pushing the capabilities of typical home shop lathes. Your Kerry is a step or two up from the typical Myford / Boxford / SouthBend / small import machine but it will still have a proper job on its hands. I've driven one and have a good idea of what they can do. Doesn't get to be routine until you hit proper toolroom lathes like mine.
